Aux belt/tensioner/pulley thing!
RedM
aux belt tentioner is a 10 minute job to change, nothing has to come off bar the spark plug cover, top timing cover and the belt itself
Going nowhere near the cambelt, if you wanted to change this a lot more stuff has to come off, usually aux tentioners start to make noise before breaking
The crank pulley (dampener) if that is what you are meaning, costs around 130 from nic, a fan belt is 10quid and you might as well change the timing belt and timing belt tentioner £60quid ish for both both an easy job
But probably not for you as you dont have the space :)
