DamanC Posted April 14, 2007 Share Posted April 14, 2007 Am i right in thinking you have to do away with the fan in front of the rad? Quote Link to comment Share on other sites More sharing options...
Steve Posted April 14, 2007 Share Posted April 14, 2007 Quick answer is yes Well i did on my 2 row FMIC. Quote Link to comment Share on other sites More sharing options...
DamanC Posted April 14, 2007 Author Share Posted April 14, 2007 I thought as much, hence why its sitting next to me now Im guessing its no longer needed and the car has no need for it? Quote Link to comment Share on other sites More sharing options...
Class One Posted April 14, 2007 Share Posted April 14, 2007 Still got mine in and mines a 4 row. Quote Link to comment Share on other sites More sharing options...
DamanC Posted April 14, 2007 Author Share Posted April 14, 2007 How did you squeeze yours in fella? Quote Link to comment Share on other sites More sharing options...
Steve Posted April 14, 2007 Share Posted April 14, 2007 I thought as much, hence why its sitting next to me now Im guessing its no longer needed and the car has no need for it? Its just the aircon fan. So no real need for it. You may just notice your aircon being slightly warmer if stuck in traffic. Quote Link to comment Share on other sites More sharing options...
Class One Posted April 14, 2007 Share Posted April 14, 2007 How did you squeeze yours in fella? It was a tight squeeze, had to lose the active spoiler an all the gubbins and shave a bit off the inside of the nose cone. But its in there, just. Quote Link to comment Share on other sites More sharing options...
Homer Posted April 14, 2007 Share Posted April 14, 2007 Am i right in thinking you have to do away with the fan in front of the rad? Which fan Daman? There's 2 or 3, the Big viscous fan and the little air con one (I think some have another small one but don't recall what it does). These are behind the rad though. Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted April 14, 2007 Share Posted April 14, 2007 Still got mine in and mines a 4 row. Yep, me too! Quote Link to comment Share on other sites More sharing options...
DamanC Posted April 15, 2007 Author Share Posted April 15, 2007 Which fan Daman? There's 2 or 3, the Big viscous fan and the little air con one (I think some have another small one but don't recall what it does). These are behind the rad though. The one in front of the radiator. Not the uber viscous bad boy, the smaller one (although its not that small). I cant see how you would me it fit either. Mines only a two row and seeing where your told to mount it there is probably nearly and inch of extra space needed. Im guessing extra 'rows' are added to the front of the IC (foward if the mounting points) so the distance from the radiator to the IC remains the same wheathers its a 2,3,5 row? Did you fellas have to mod the fan in any way? Quote Link to comment Share on other sites More sharing options...
Homer Posted April 15, 2007 Share Posted April 15, 2007 The one in front of the radiator. Not the uber viscous bad boy, the smaller one (although its not that small). I cant see how you would me it fit either. Mines only a two row and seeing where your told to mount it there is probably nearly and inch of extra space needed. Im guessing extra 'rows' are added to the front of the IC (foward if the mounting points) so the distance from the radiator to the IC remains the same wheathers its a 2,3,5 row? Did you fellas have to mod the fan in any way? The number of rows has nothing to do with the thickness of the IC. It's really not clear to me whether the fan you refer to is beforeor after the rad. If you are standing in front of the car is the fan before or after the radiator? If it's before then I'm stumped! Might be an auto thing. Quote Link to comment Share on other sites More sharing options...
DamanC Posted April 15, 2007 Author Share Posted April 15, 2007 Its before Browsing mkiv i found a snap but its missing the fan there should be one to the top right of the rad Quote Link to comment Share on other sites More sharing options...
_Rob_ Posted April 15, 2007 Share Posted April 15, 2007 My UK didnt have a fan there, so no need to remove it! Quote Link to comment Share on other sites More sharing options...
wez_p Posted May 7, 2007 Share Posted May 7, 2007 i've just had to remove a fan from the front of the radiator (the bumper side rather than the engine side) to fit the FMIC in mine's a facelift which i thought might have been the reason for it being there, but if yours is pre-facelift Daman then i'm wondering if it's an auto thing, since Gareth Eves didn't have one on his manual i'll grab a picture of it later Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted May 7, 2007 Share Posted May 7, 2007 I replaced my air con fan with an ultra slim Spal Unit....fits like a glove and still retains the cooling properties when your sitting at lights of in traffic etc Quote Link to comment Share on other sites More sharing options...
TrickTT Posted May 7, 2007 Share Posted May 7, 2007 I replaced my air con fan with an ultra slim Spal Unit....fits like a glove and still retains the cooling properties when your sitting at lights of in traffic etc Make sure you get a push version rather than a pull one though. Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted May 7, 2007 Share Posted May 7, 2007 Its before the aircon rad. Must be an auto thing. I removed mine while removing the aircon Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted May 8, 2007 Share Posted May 8, 2007 Daman, Here is a pic of my car several moons ago when I was fitting my Hybrid FMIC. The fan is standard to Facelift Auto's and I managed to keep mine by tilting the FMIC only a few degrees from the vertical - it works a treat and you should be able to do that with yours as the Hybrid FMIC is quite a big beast;) Quote Link to comment Share on other sites More sharing options...
wez_p Posted May 8, 2007 Share Posted May 8, 2007 Daman, Here is a pic of my car several moons ago when I was fitting my Hybrid FMIC. The fan is standard to Facelift Auto's and I managed to keep mine by tilting the FMIC only a few degrees from the vertical - it works a treat and you should be able to do that with yours as the Hybrid FMIC is quite a big beast;) ah yes, that's the fella! to the right behind the crash bar do you know what exactly it's for? assuming the non-facelifts did ok without it, i'm of the opinion it should be fine being removed although i am wondering about getting a couple of new brackets made up to make the intercooler sit further forward and a touch lower so it will sit more flush with my Do Luck bumper Quote Link to comment Share on other sites More sharing options...
Rico2006 Posted May 8, 2007 Share Posted May 8, 2007 I removed my fan. Then again, i also removed the aircon rad as well as i had a little mishap. The fan really isnt needed in the UK. Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted May 8, 2007 Share Posted May 8, 2007 ah yes, that's the fella! to the right behind the crash bar do you know what exactly it's for? assuming the non-facelifts did ok without it, i'm of the opinion it should be fine being removed Wez mate, it is the AC fan that aids the cooling capability of the AC rad. As you have already mentioned, you can remove it and I personally don't think it will have a massive derogatory affect on the cooling; especially as we live in the UK and not some hot country (lol). This was one of the added designs that Toyota included in the Facelift package. Cheers mate;) Quote Link to comment Share on other sites More sharing options...
DamanC Posted May 8, 2007 Author Share Posted May 8, 2007 Christ this was dug out a little I ditched mine in the end, i went on the theory that we dont need them here, althou saying that my aircon has given up........that may have someting to do with me undoing the aircon system accedently when moving it a little Ive never moved so frekin fast in my life to get a better angle on doing it up! Quote Link to comment Share on other sites More sharing options...
wez_p Posted May 8, 2007 Share Posted May 8, 2007 Wez mate, it is the AC fan that aids the cooling capability of the AC rad. As you have already mentioned, you can remove it and I personally don't think it will have a massive derogatory affect on the cooling; especially as we live in the UK and not some hot country (lol). This was one of the added designs that Toyota included in the Facelift package. Cheers mate;) cheers dude, i feel a lot happier about the wreckless removal that was undertaken on Sunday now! Quote Link to comment Share on other sites More sharing options...
