My VVTI GT35R Single Conversion
MarkR
Right, I've decided to take the plunge and am starting to buy all the parts required for my small single conversion. I've listed the parts that I already have (collected over the last few years), and will list what I'm planning to buy below. As usual, advice would be great.
Solaris S6GP ECU
HKS turbo kit from T04Z with GT35R turbo
Power Enterprise 650cc Injectors
Bosch Fuel pump
AEM Water injection
SSQV BOV & weld on flange
Defi EGT gauge & link II controller
HKS Valcon plus intake cam & controller (VVTI)
Blitz LM Front Mounted Intercooler with hardpipes
New O2 sensor
Innovate Wideband O2 sensor (LM1) and gauge (XD16)
RSR EXMag GTII Exhaust
Driftworks Oil Cooler
6 speed conversion
Solaris Boost solenoid
Solaris 3bar Map sensor
Anti Surge housing for GT35R
Southbend Clutch and new flywheel
Turbo Blanket from Kyle
TRD gearbox mounts
Whifbitz catch tank
Unorthodox Racing pulleys
Brembo front brakes
UK Rear Calipers
DBA 4000 disks all round and braided Goodrich hoses
Bilstein Shocks & Eibach lowering springs
NGK Plugs
New Cambelt, Radiator Cap & Thermostat
New Top Secret Rear Spoiler
APR Carbon fibre radiator cooling plate
Leather facelift seats
Titan anti-roll bars
The guys doing my single conversion are SPC in Horsham. Great bunch with good skills. http://www.spchorsham.com/
Edited by MarkR (see edit history)
  • Replies 494
Posted Images
Guest Nicholas
Interesting build, you're missing leather seats though ;)
Whats the maximum power the tiptronic box can cope with?
haha :) Shameless hint!
The box is the same as the auto box if you believe the serial number, so I reckon up to 500bhp'ish. I'll go 6-speed eventually but for now it'll have to do.
Fuel upgrade - undecided
Either:
From Nic
HKS 680cc Injectors
HKS Fuel Rail Kit
Fuel Lines made up the same as his
Aeromotive FPR (sourced seperately)
New fuel pump (undecided as to what to get as I'd like one that's not too noisy)
OR
PHR stage 1 Fuel kit
PHR 17.5mm (-10AN) ID high-flow fuel rail
Twin Walbro GSS341 in-tank fuel pumps
Aeromotive EFI fuel pressure regulator with liquid-filled fuel pressure gauge
Fully assembled and pressure tested -6AN Stainless Steel braided fuel lines
hi-flow fuel filter
Siemens 720cc fuel injectors
PHR quick release injector clips and all hardware necessary for a complete install including a sheet of a space-age polymer used to wrap the fuel pumps to prevent magnetic interference.
OR
Titan Motorsports Fuel Kit
Titan Fuel Rail
720cc Injectors
Aeromotive Fuel Pressure Regulator
Braided lines with Aeroquip fittings
Additional Supra Pump (couple with existing pump)
Twin in-tank fuel pump kit
All connectors, pre-cut wiring, instructions, Relay etc.
Or..... Just
Set of PE 650cc injectors - cleaned and flow tested
Walbro fuel pump
For the power you want dont waste money on aftermarket rails, FPR and lines which are just not as reliable as the stock toyota, denso and bosch parts.
Ryan
Would I need to do the 12V fuel pump mod as well?
Not if you are running a standalone.
The 12v mod is generally considered bad as the pump would continue to run in the event of an accident if there power still going to it :blink:
Unless you have future plans for a bigger turbo (in the next years), I agree on the fact that you should not waste your money on a complete fuelling kit. Just use drop-in injectors and eventually upgrade the pump.
You'd definitely need to upgrade the pump on a J-spec, a single Walbro 255Lhr (GSS342) pump would be sufficient.
Cheers Wez... my name has been added.
While I'm here... Will PE 800 injectors be too big for this project?
If you have a resonable replacement ECU controlling them 800cc should be fine, also leaves head room to expand later if you want.
Edited by Wez (see edit history)
The PE 650cc injectors would be adequate, I run HKS 680cc injectors at low 80% duration. You could fit 800cc ones if you perhaps wanted to fit a bigger turbo later.
I just noticed some for sale which was why I was asking..... ;) Is there any downside? I seem to recall something about idling being affected by larger ones.
Only really affects certain ECU and injector combos.
I have seen perfectly fine idles on 1000cc injectors when setup properly.
What ECU are you planning on using?
The advantage of the PEs is they negate the need for a resistor pack or peak and hold driver.
Not if it is wired correctly. Use the signal wire from the ECU to control the relay then the pump would run like stock but 12v. ;)
Ahh I see.
When using aftermarket ECUs like the AEM they run constant 12v anyway.
Not sure of the ECU yet. Still undecided as I don't have enough info on the subject. I've searched like mad and have so many conflicting ideas. My issue is the VVTI/auto combo, mixed in with the lack of HKS tuners and new products coming onto the market (RyanG knows of a new ECU that he'll let me know about). The new ProEfi looks awesome but I have yet to find a wealth of info on it.
VVTI/auto :(
Bit of a nightmare as you have to control the VVTI, drive by wire and the autobox.
The AEM can control the VVTI and auto but not sure about DBW.
I would go with what ever Ryan suggests :D
