GazzaGSi Posted August 5, 2006 Share Posted August 5, 2006 Very pleased with myself The gauge itself was too small for the hole that the fan came out of. So I dismantled the fan and put the gauge inside the casing that the fan is held together in. As you can see from the pic, the gauge was a perfect fit for the fan casing, and as I used the fan casing, it slotted straight back in the hole it came out of! I fed the wiring harness behind the dash and its now under the carpet. Looks really great, was very proud of myself, just need to wire it in and 'T' it in to the correct pipe. Almost looks a factory fit Link to comment Share on other sites More sharing options...
MR.B Posted August 5, 2006 Share Posted August 5, 2006 That looks really good bud well done! Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted August 5, 2006 Share Posted August 5, 2006 Thats great....well done Link to comment Share on other sites More sharing options...
GazzaGSi Posted August 5, 2006 Author Share Posted August 5, 2006 Thanks! I also still have the manouverability (sp) as if it were still the fan! Link to comment Share on other sites More sharing options...
Gaz Walker Posted August 5, 2006 Share Posted August 5, 2006 Excellent job of that, it does look OEM! Gaz. Link to comment Share on other sites More sharing options...
GazzaGSi Posted August 5, 2006 Author Share Posted August 5, 2006 Thanks guys Link to comment Share on other sites More sharing options...
Ian R Posted August 5, 2006 Share Posted August 5, 2006 Impressive Link to comment Share on other sites More sharing options...
edd_t Posted August 5, 2006 Share Posted August 5, 2006 looks tidy and you have the same head unit as me. Link to comment Share on other sites More sharing options...
stupra Posted August 5, 2006 Share Posted August 5, 2006 Nice job buddy, looks real smart. Good idea of using the oem vent housing to. Link to comment Share on other sites More sharing options...
rik Posted August 5, 2006 Share Posted August 5, 2006 That looks real nice. Proper factory fit! What size guage is that to fill that hole so well? I'll be needing one at some point. Link to comment Share on other sites More sharing options...
GazzaGSi Posted August 5, 2006 Author Share Posted August 5, 2006 Thanks for the comments Unsure what size it is, I will measure it for you. Link to comment Share on other sites More sharing options...
Big Ads Posted August 5, 2006 Share Posted August 5, 2006 I was staring at it for ages trying to think what should have been there!! so must be subtle. Looks great. Link to comment Share on other sites More sharing options...
imi Posted August 5, 2006 Share Posted August 5, 2006 please do, cause my blitz gauge is too small and id like to fit it the same way... any instructions. Link to comment Share on other sites More sharing options...
toyotasuprauk Posted August 5, 2006 Share Posted August 5, 2006 Looks great! You might get a bit hot or cold now though. Link to comment Share on other sites More sharing options...
Guest dee_rz Posted August 5, 2006 Share Posted August 5, 2006 Have you been looking in my car i done this last year exactly the same place and exactly the same greddy gage too it's freeky looks awesome doesn't it, nice going bud Link to comment Share on other sites More sharing options...
GazzaGSi Posted August 5, 2006 Author Share Posted August 5, 2006 please do, cause my blitz gauge is too small and id like to fit it the same way... any instructions. Here's what I did. Removed the panels on the dash so removal of the fan/vent was accesable. Holding the fan in place behind the dash is a plastic bracket which has 3 small plastic clips coming off it. Gently (so they dont break) lever back the 3 clips and slide the bracket backwards. You can now push the vent backwards and it pops out. The vent has a plastic mesh net on the back, use a pair of snips to cut the mesh off as the back of the gauge comes out further than what the mesh would allow if left on. Now the fan casing is in 2 parts and held together by 3 plastic clips on the inside. Gently lever the clips back and the casing will come apart in to pieces. The open/close part of the fan can now be removed. Put the gauge flush with the part of the fan casing which faces the front of the dash and reassmble the rear - sliding the rear section of the assembly over the gauge and locking the 3 plastic clips in place. I had to pack the middle of the fan casing as the casing is of a oval shape and the gauge was not sturdy - depending on the gauge I guess you would have to do this. I then got a A5 plastic wallet and ziptied it over the hole that the air would come out of. Put the bracket back on that locks the fan assembly to the dash. Do not forget to feed the wiring harness from the back of the gauge behind the dash so wires are hidden. My wires came out in the passenger footwell and are now tucked under the carpet. Reassemble dash. Pretty much it to be honest. Will read it over afew times to see if it needs editing as I may have missed something. Cheers (and thanks again) Gaz Link to comment Share on other sites More sharing options...
imi Posted August 5, 2006 Share Posted August 5, 2006 thx bud Link to comment Share on other sites More sharing options...
GazzaGSi Posted August 5, 2006 Author Share Posted August 5, 2006 no problem need anymore help send us a pm and i'll be alittle more indepth Gaz Link to comment Share on other sites More sharing options...
GazzaGSi Posted August 5, 2006 Author Share Posted August 5, 2006 Looks great! You might get a bit hot or cold now though. hehe, to be honest I hated that vent anyway, whenever I had it on it always used to blow in my eyes! Usually have it set on the controls to point at my feet Link to comment Share on other sites More sharing options...
GazzaGSi Posted August 5, 2006 Author Share Posted August 5, 2006 Have you been looking in my car i done this last year exactly the same place and exactly the same greddy gage too it's freeky looks awesome doesn't it, nice going bud Just checked you garage and you have no pics! Get it updated! And sorry no i havnt seen your car, I guess two great minds think alike! Yep, I really like it Link to comment Share on other sites More sharing options...
markrzs Posted August 5, 2006 Share Posted August 5, 2006 I've also done this mod with my Blitz boost guage, it's the perfect place tbh. Does look factory fit Gaz, well done ! Link to comment Share on other sites More sharing options...
glenn Posted August 5, 2006 Share Posted August 5, 2006 done a good job there,i'm trying to locate the same gauge but mechanical version,as i have a 52mm already connected ,but want to relocate to air vent.what is involved in fitting eletronic gauge? as i may have to use this type Link to comment Share on other sites More sharing options...
supragold Posted August 5, 2006 Share Posted August 5, 2006 My Greedy gauge is in the same place but doesn't look as tidy as that. Nice work. Link to comment Share on other sites More sharing options...
terribleturner Posted August 5, 2006 Share Posted August 5, 2006 Looking really good Gaz Love the idea of it being able to swivel round. Link to comment Share on other sites More sharing options...
Tom Posted August 5, 2006 Share Posted August 5, 2006 Looking really good Gaz Love the idea of it being able to swivel round. Agreed, I can see a fair few of these greddy units beng sold now! Link to comment Share on other sites More sharing options...
