Guest martin169 Posted May 6, 2006 Share Posted May 6, 2006 has anyone had trouble with the roof leaking? where can i get a new roof and door seal? martin Link to comment Share on other sites More sharing options...
Jezz Posted May 6, 2006 Share Posted May 6, 2006 Get this every time it rains. I should imagine nic (import pimp) may be able to get these new. Link to comment Share on other sites More sharing options...
aeropete Posted May 7, 2006 Share Posted May 7, 2006 i have this same trouble most of the time mate. it all depends on the way i put the roof back on tho?? i used to just sit the roof back on and jus do the bolts up equaly. now i gotta sit the roof on, then climb inside grab both sides of the roof, and push it right back in tight and make sure the front lines up perfect to the sides of the font window. Then start by tightening up the back two bolts first then the front two. i know it sounds like it doesnt make alot of difference but it works for me. well if it does leak its nothing alot like it used to. good luck sorting out your leak mate:) Link to comment Share on other sites More sharing options...
Ewen Posted May 7, 2006 Share Posted May 7, 2006 Blocked drains ? Link to comment Share on other sites More sharing options...
Digsy Posted May 7, 2006 Share Posted May 7, 2006 Mine sometimes leaks in the corners at the top of the A-pillars. I can fix it by rubbing some rubber grease on the face where the seals on the windscreen hoop and roof touch. Link to comment Share on other sites More sharing options...
gdc Posted May 7, 2006 Share Posted May 7, 2006 mine never leaks but i do the same back bolts first:d Link to comment Share on other sites More sharing options...
Pedroby Posted May 7, 2006 Share Posted May 7, 2006 It depends on the way you fot it. Fit it like the insctruction booklet says. That will make sense! Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted May 7, 2006 Share Posted May 7, 2006 mine leaks but if it rains it stays in the garage Link to comment Share on other sites More sharing options...
dangerous brain Posted May 7, 2006 Share Posted May 7, 2006 Mine leaked but I found it was down to poor adjustment of the drivers door window. Link to comment Share on other sites More sharing options...
jim_supra Posted May 7, 2006 Share Posted May 7, 2006 Mine leaks sometimes too, as said above I guess it's down to how it's re-fitted. Link to comment Share on other sites More sharing options...
sooper-supra Posted May 7, 2006 Share Posted May 7, 2006 Dw i took mine out tonight leaked on the seat so had a wet ass when got home lol Link to comment Share on other sites More sharing options...
jim_supra Posted May 7, 2006 Share Posted May 7, 2006 Dw i took mine out tonight leaked on the seat so had a wet ass when got home lol Lol. I keep one of those plastic seat covers in the car for just that emergency! Link to comment Share on other sites More sharing options...
lpher Posted May 7, 2006 Share Posted May 7, 2006 Lol. I keep one of those plastic seat covers in the car for just that emergency! Dont the JDM's have heated frontseats then?! Link to comment Share on other sites More sharing options...
jim_supra Posted May 7, 2006 Share Posted May 7, 2006 no comment Link to comment Share on other sites More sharing options...
Tom S Posted May 7, 2006 Share Posted May 7, 2006 no comment Link to comment Share on other sites More sharing options...
aeropete Posted May 7, 2006 Share Posted May 7, 2006 had roof off this morning, had it back on this afternoon before a heavy downpore, no leak!! woo hoo think iv sussed it. had no instructions with it but definitely gotta bolt back two first. Link to comment Share on other sites More sharing options...
aeropete Posted May 7, 2006 Share Posted May 7, 2006 and what are those two wiper blade thingies that spring ubove the windscreen wen the roof is off?? they make a hell of a racket wen im goin some! i have to hold them down with my hand Link to comment Share on other sites More sharing options...
markssupra Posted May 7, 2006 Share Posted May 7, 2006 I always do the back bolts first. lucky enough I dont have any leaks. Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted May 7, 2006 Share Posted May 7, 2006 had roof off this morning, had it back on this afternoon before a heavy downpore, no leak!! woo hoo think iv sussed it. had no instructions with it but definitely gotta bolt back two first. there should be a sticker under the center glove box, box thingy its in japanese but the diagram is numbered Link to comment Share on other sites More sharing options...
steve0 Posted May 7, 2006 Share Posted May 7, 2006 ye ive got those wind things aswell and they do make hell of alot noise can they be reomoved Link to comment Share on other sites More sharing options...
aeropete Posted May 7, 2006 Share Posted May 7, 2006 quote*there should be a sticker under the center glove box, box thingy oh yeah wondered what that was cheers Link to comment Share on other sites More sharing options...
dangerous brain Posted May 8, 2006 Share Posted May 8, 2006 and what are those two wiper blade thingies that spring ubove the windscreen wen the roof is off?? they make a hell of a racket wen im goin some! i have to hold them down with my hand They are wind deflectors. They are meant to drop down at about 60 mph. Alot don't due to age or someone bending them a bit when fitting roof. Stick em down with a bit of blu-tack. You could always go ask a guy called mark on the supraforums US side if you can remove them. Anyone remember that delightfully entertaining thread Link to comment Share on other sites More sharing options...
RobSheffield Posted May 8, 2006 Share Posted May 8, 2006 You could always go ask a guy called mark on the supraforums US side if you can remove them. Anyone remember that delightfully entertaining thread yes, what a pleasant young man...a veritable ambassador for international relations:D Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted May 19, 2006 Share Posted May 19, 2006 hi im thinking of investing in my first supra ! ive seen a 94 aero top mint condition 53000 miles on the clock with BIMTA certificate for 6 grand! is this a good car for the money as its totally standard ( well for the time being ) also whats best manual or auto's ??? Link to comment Share on other sites More sharing options...
Jezz Posted May 19, 2006 Share Posted May 19, 2006 They didnt make a rhd manual aerotop mate. 6k for an n/a auto aero sounds about right though. Link to comment Share on other sites More sharing options...
