Jamesy's Billet 6765H Single Conversion ...!
Jamesy
Right this is the new thread as the other one was started a bit early and didnt have enough pics for some members :)
Work begun on this project yeserday ......
I have decided to go with the impressive Billet 6765H DBB .81ar Turbo!
Would like to see 630-650bhp once Ryan has finished and then next year will sort out a complete new fuelling system with Lee to get over 700bhp :)
All the work is being done by Lee at SRD who i cannot recommend highly enough:
http://www.supraracingdevelopment.co.uk//
And the mapping will be done by Ryan G at 2bartuning:
http://www.2bartuning.com/
My car is currently at BPU level so some modifications have already been done, although most of it will be replaced during the conversion:
* Walbro 255lhr fuel pump
* Blitz DD Bov
* CW 1st and 2nd decat pipes
* CW R/Ring
* Thor FCD
* Blitz dual SBC type R boost controller
* GReddy FMIC
* Denso iridium plugs
* Oil pressure and Oil temp gauges
* Boost gauge
Before:
After: :D
Below is the spec i have decided to go for:
* Billet 6765H DBB Turbo with .81ar :D
* Custom SRD Heat Shield
* Modified OBX 321 stainless steel manifold
* HKS 50mm wastegate with screamer pipe :D
* 4" Full-Race Pro Sport downpipe
* 4" Full-Race Pro Sport mid pipe
* 4" HKS Ti catback exhaust :D
* 4" SRD Front Mount Intercooler with custom piping
* 4" Inlet pipe and K&N air filter
* SARD 800cc drop in injectors
* SRD Stage 2 Race Cams :eyebrows:
* Brian Crower uprated springs and retainers
* HKS cam pulleys
* GReddy Plenum, throttle cable and TPS adaptor
* Q45 Throttle body
* GReddy timing belt
* F-Con V Pro Gold ECU
* Bosch 044 fuel pump
* AEM AFR gauge and wideband sensor
* AEM trans temp gauge
* Blitz oil cooler and relocation kit
* 2 x SRD Gearbox coolers
* Gearbox cooler gauge
* Uprated Boostlogic autobox (built by Michel Lane)
* 3800 Hi Stall torque converter
* Line lock kit
* BC Racing fully adjustable coilovers
* LSD
* UK Spec brakes front and rear with 3G drilled and vented discs and CW fast road pads
* Resprayed UK Calipers in silver with black decals
* CW braided brake hoses front and rear
* Alloy Overflow Tank
* GReddy Timing Belt
* Fuel Pulsation removal kit
* FPR, gauge and rail adaptor
* New Water Pump
* New valve stem seals
* TRD Thermostat
* SRD Polished Greddy Manifold, Q45 Throttle Body, Water Neck & Cam Covers
Will keep this thread updated as we go!
:D
*** Updated pics ***
vHOHtGvTHq8
Edited by Jamesy (see edit history)
  • Replies 1.2k
If I were using XS Power anywhere I think the DP/MP must be the safest bet, hell it's only a length of pipe :D
Good luck with the project, it's in good hands, and in for the updates
I had the xs power down and midpipe on my blue supra and they were a mile away I had to take them into work to be modded.
Did you get the exhaust from captain chaos. Sounds like his old system jamesy
Yes mate i did - to be honest its at the welders now as wasn't in tip top condition around the joins so we'll see what they can do with it and offer it all up soon - if it fits then great if not we'll go a different route :)
Might have to change my wheels soon :(
I really like them but they are 18x9.5 rears and with the new power traction may become a real issue.... on the lookout for some seriosuly deep dish alloys something like 18x11.5 rears.
(If anyone can find the ones i currently have "Vertec Manary Sport" please let me know as i'll just buy two 18x11.5 for the rears and put the current rears on the front :) )
To get us started here is a couple of pics of the engine bay before we begin. :)
Very nice turbo should give James the spool and power he was looking for. :)
Starting the strip down, no going back now mate. :)
