ripped_fear Posted April 21, 2014 Share Posted April 21, 2014 Hi all I know that one of my j-spec front calipers is starting to bind. So decided to change them but thinking of changing to uk fronts for the extra stopping capabilities. So first diahlema is, is running uk fronts and j spec rears a good idea? or will it though out the balance and make in unpredictable? Im not going to change the rears as they were brand new oems installed only a couple of years back, along with new pads and disks. If this is ok to do, I seem to remember someone doing a template to print out to see if wheels clear uks, could someone point me in that direction please, as i keep hitting blanks. Quote Link to comment Share on other sites More sharing options...
Benjy Posted April 21, 2014 Share Posted April 21, 2014 I'm running UK fronts and J-Spec rears. Stops ok. What wheels have you got? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 21, 2014 Author Share Posted April 21, 2014 Currently running Volk racing Av's 3 piece split rims, but they are 17" not 18". Will be changed soon but if i go for uk brakes probably hold off on new wheels for an extra 6months or so. Can be seen here http://www.mkivsupra.net/vbb/showthread.php?305017-Gauging-interest-Volk-3-piece-wheels Quote Link to comment Share on other sites More sharing options...
clay Posted April 21, 2014 Share Posted April 21, 2014 I put big brembos on mine today. seem fine with the j spec rears. Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 21, 2014 Share Posted April 21, 2014 (edited) The issue could well be with the clearance between the inner surface of the spokes to the caliper face, arrowed in yellow rather than the inner diameter of the wheel My Work Equips were very close to the back of the spokes Edited April 21, 2014 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted April 21, 2014 Share Posted April 21, 2014 I have uk fronts and j spec rears and car stops fine aswell Quote Link to comment Share on other sites More sharing options...
Benjy Posted April 21, 2014 Share Posted April 21, 2014 I think it'll be mega close if they do fit over them. Quote Link to comment Share on other sites More sharing options...
listy Posted April 21, 2014 Share Posted April 21, 2014 I also have UK fronts and JSpec rears with no dramas. Find someone local to you that has UK brakes, and test fit a wheel. Quote Link to comment Share on other sites More sharing options...
thetrashcanman Posted April 21, 2014 Share Posted April 21, 2014 You'll probably find the rears start to fade, if you are pressing on hard but you'd have to be doing some silly speed, uk fronts, j-spec rears with chris wilson pads is a great combination Quote Link to comment Share on other sites More sharing options...
Dazzi Posted April 21, 2014 Share Posted April 21, 2014 Most US owners fit jap rears (NA) with UK fronts (TT) to allow clearance for 15/16" drag wheels. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 22, 2014 Author Share Posted April 22, 2014 ok cheers guys, I know a couple of people with uk's so I will send some cheeky pm's If they fit im thinking I may aswell go for them. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 22, 2014 Share Posted April 22, 2014 Brake upgrades can set out to try to achieve several objectives. The commonest are to increase resistance to fade and or increase braking effort for a given pedal effort. IE, the pads are pushed against the discs harder for a given pedal effort than before the upgrade, or the brakes will stop the car from 100 MPH, hard, for more times before fade sets in, than previously. The feel from the pedal, that almost intangible quality, can also be addressed and sometimes improved upon by brake size, or pad material changes, or brake flexi hose upgrades to something less squashy than rubber. It's easy to get carried away by the thought of brake upgrades. The limitation in most cars as to how short a distance they can stop in is tyre friction. Leaving aside pedal feedback, and fade, it is almost certain that a Supra on stock Jap spec brakes will stop in just as short a distance as one with an AP six pot kit on it, a Brembo kit, Pauls KAD kit, or whatever. It may not feel to the driver that it does, but usually such is the case if you just nail the pedal as hard as you can. The fancy kits may *FEEL* to stop the car faster, due to less pedal effort, and a better bite, but in reality, if you hit the pedal as hard as you can with stock Jap spec brakes, UK spec brakes, AP kit, KAD, whatever, the car will stop in the same distance. Repeat this test 10 times and stock Jap brakes may be on fire and long since faded, or the fluid boiled, UK ones may be very hot and bothered, but the upgraded ones will probably still be working within pad, disc and brake fluid temp limits. Add in the intangible "feel" factor, and a desire to brake as hard as possible, using as little skill as possible, but WITHOUT relying on the ABS to take over, and for sure a well set up brake upgrade may well allow more finesse. Herein though lies the rub. Upgrade only the fronts and the brake balance of the stock car may well be compromised. Let's take stock brakes. You press smoothly on the brake pedal with (say) 50 pounds force. The car stops fine. 70 pounds, the fronts are just beginning to lock (car makers ALWAYS aim for the fronts to lock first, as rear wheel lock makes the car very unstable and liable to swap ends). The rears are doing as much work as the brake engineers deemed safe to prevent premature rear lock up. The ABS cuts in, and maximum retardation has been reached. Now, take a car with big front discs and calipers. Only 40 pounds pressure now gives a smooth, lock free and powerful retardation. 50 pounds and the new, more powerful, (for the same pedal pressure), fronts are locking. The ABS cuts in. BUT, and this is the crux, those original rear calipers and discs are still well below the caliper pressure where they are able to achieve maximum retardation without fear of the rears locking. In other words the FRONT brakes are doing TOO MUCH work, albeit without breaking into a sweat, and the rears are, to exaggerate a bit, just along for the ride. The BEST scenario is to upgrade front AND rear brakes, carefully ensuring the original balance of effort at any given brake pedal pressure remains as designed, but that the more efficient front AND rear brakes stay cooler for more hard stops, and that old intangible "feel" from the brake pedal is improved, at lower rates of driver effort on the pedal. The latter may or may not be good or desirable, and can be engineered out by changing BOTH front and rear caliper piston sizes, or pad areas. In a race car the balance would be adjustable via 2 brake master cylinders, with a driver selectable change in mechanical leverage effort between front and rear brake circuits, one cylinder operating the front brake calipers, the other the rear. This can also be achieved on road cars, but to do so is usually complex and expensive, especially if ABS and brake circuit failure safeguards are to be maintained. It is far easier to calculate the caliper and disc sizes, along with pad area and compound to achieve this, as near as available off the shelf equipment will allow. Caveat. I said before makers engineer more effort on the front brakes to encourage straight line stopping if the tyres are locked up . They err on the excessive side, as, in the wet, the rear tyres can take a lot more braking effort than in the dry, due to less weight transfer onto the front tyres, as they will lock before as much weight is transferred when the grip of the road surface is reduced. So adding yet more front brake effort worsens this existing imbalance, especially in the wet. If it were not for the ABS the front wheels would be locking up very early. On the Supra a relatively sophisticated ABS allows some effort to be taken off JUST the fronts, and an artificial and very inefficient balance is returned. On cars with lesser (1 or 2 channel) ABS, or no ABS at all, a brake upgrade on just one end of the car can be lethal. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 23, 2014 Author Share Posted April 23, 2014 Thank you for the in depth right up Chris that's the type of information I was looking for. And having read that maybe I would be better off just swapping for a new set of j-spec fronts with oem disks and a decent set of pads then, as I already have relatively new rears this would make the most logical sense. I will price up the comparison of the jspec fronts against at whole set of UK's and make the decision from there. Out of interest do you sell Brake set ups Chris? I know you do your pad setups, but do you supply callipers and disks. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 23, 2014 Share Posted April 23, 2014 Whilst UK fronts with J-Spec rears work safely, they are not optimal, the rears are not doing their potential. I sell OE disks, and race discs, and race calipers. I do not sell OE calipers, but do seal kits, when I find stock, and do my own stainless steel pistons for Supra and any other caliper that needs refurbishing that uses "normal" piston designs. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 23, 2014 Author Share Posted April 23, 2014 What sort of price do you charge then for a rebuild on jspec front brakes, if I did both for piece of mind along with new pads and disks and a fluid change. The car is not raced and its only an NA so something that would suit those needs would be great. If I brought the car to you how long would it take also? Ben nice to have the brakes and everything looked over properly as these cars are getting old these days. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 23, 2014 Share Posted April 23, 2014 So long as you don't want fancy powder coating or anything (I only offer satin black Kephos coating on a basic bead blasted caliper), and assuming you wanted my stainless pistons and new seals fitted, the front calipers would cost about £160 each, with the slider pin bores reamed and correctly greased with new seals. It's impossible to give a totally firm price without looking at the calipers and sliders. OE discs would be whatever Toyota are currently charging, but I have TUV pattern ones for less. A fluid flush and change wouldn't be much at all with the above work, perhaps an additional £20 Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 23, 2014 Author Share Posted April 23, 2014 Brilliant thankyou that gives me some ball park figures to work with and compare against OEM new ones etc. If I was to get the car to you first thing in a morning is it a job that is do-able in a day or would you need the car for an extended amount of time? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 23, 2014 Share Posted April 23, 2014 I'd need it a few days, no point in you buying stainless pistons if not needed as the old ones are still fine, these jobs take time unless I were to just throw all new parts at it, which is a half day's work or so. Quote Link to comment Share on other sites More sharing options...
Noz Posted April 23, 2014 Share Posted April 23, 2014 If your not going for power, there's not point in going for UK brakes. Only problem I ever had when first NA-t with 373hp was on a track. Never ever had a problem on the road with stock jspec fronts pads/discs. Save yourself some cash. Quote Link to comment Share on other sites More sharing options...
Nic Posted April 23, 2014 Share Posted April 23, 2014 If I had the smaller brakes fitted and they needed completely overhauling (calipers refurbed, new discs & pads etc.), I'd personally take the opportunity to upgrade to the larger brakes front and rear. I'd price up the 2 options and then make a decision. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 24, 2014 Author Share Posted April 24, 2014 I'd need it a few days, no point in you buying stainless pistons if not needed as the old ones are still fine, these jobs take time unless I were to just throw all new parts at it, which is a half day's work or so. Right ok Thankyou for the information, I will price up the comparison against brand new oem j-specs and a full set of uk specs. If your not going for power, there's not point in going for UK brakes. Only problem I ever had when first NA-t with 373hp was on a track. Never ever had a problem on the road with stock jspec fronts pads/discs. Save yourself some cash. It will have more power one day, but I ruled out the idea for now but the car is going to stay now and will probably go na-t in the future so I like the car to be setup ready to go. Its never going to be a big power car but small single power would probably be where it stops. I've been spending the cash on making sure everything is new and ready to go, rather than chucking a snail on and hoping. If I had the smaller brakes fitted and they needed completely overhauling (calipers refurbed, new discs & pads etc.), I'd personally take the opportunity to upgrade to the larger brakes front and rear. I'd price up the 2 options and then make a decision. This is the thing Nic if the rear where had it too I would just go for a full new uk set-up but alas the rears are only a 1 and 1/2 years old. This is the only thing holding me back. Quote Link to comment Share on other sites More sharing options...
