mattsson Posted August 28, 2012 Author Share Posted August 28, 2012 (edited) used the car at ouer wedding Edited January 19, 2013 by mattsson (see edit history) Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted August 28, 2012 Share Posted August 28, 2012 you ran 600hp through the w58 box? crazy! ha my bad didnt read, a w59, whats that? :S Quote Link to comment Share on other sites More sharing options...
mattsson Posted August 28, 2012 Author Share Posted August 28, 2012 w59 is almost the same as w58 its a Hiace / Hilux 2wd transmission im using the w58 housings on but i hawe reinforced the housing around the bottom shaft only reason for using w59 is that they are verry chep and common in the scrapyards Quote Link to comment Share on other sites More sharing options...
David P Posted August 28, 2012 Share Posted August 28, 2012 w59 is almost the same as w58 its a Hiace / Hilux 2wd transmission im using the w58 housings on but i hawe reinforced the housing around the bottom shaft only reason for using w59 is that they are verry chep and common in the scrapyards It would be interesting to see a few pics of the modifications? Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted August 28, 2012 Share Posted August 28, 2012 ahhh ok... Was the w59 suposed to take 600hp though? Quote Link to comment Share on other sites More sharing options...
dive_popo Posted August 29, 2012 Share Posted August 29, 2012 w59 is almost the same as w58 its a Hiace / Hilux 2wd transmission im using the w58 housings on but i hawe reinforced the housing around the bottom shaft only reason for using w59 is that they are verry chep and common in the scrapyards they do a simillar reinforcement on the w58 down here, and w58 can take up to 500 bhp, even they run it on drift cars without issue Quote Link to comment Share on other sites More sharing options...
mattsson Posted November 18, 2012 Author Share Posted November 18, 2012 (edited) now the bmw gs6-53dz arrived from germany when the W59 is of the car i will post pic of the housing. The gears are still fin only hawe problem with shiifter fork that come lose Edited January 19, 2013 by mattsson (see edit history) Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 18, 2012 Share Posted November 18, 2012 Fantastic build mate Quote Link to comment Share on other sites More sharing options...
Brazil Posted November 19, 2012 Share Posted November 19, 2012 used the car at ouer wedding [ATTACH=CONFIG]156904[/ATTACH] [ATTACH=CONFIG]156905[/ATTACH] Congratulations...! That's a sick burnout in the parking lot..! ILMAO.....! Quote Link to comment Share on other sites More sharing options...
mattsson Posted December 30, 2012 Author Share Posted December 30, 2012 (edited) Her is a pic of the welding on the outside of the housing i hawe no pic of the inside but i hawe filled the empty room under the lower shaft front bering just above the outside modification hope this explains what i meean. And then i hawe a new fault with the W59 box the 3-4 Syncro slider But now to the mor fun part the Mod off the Bmw ZF Gerbox First Cut apart aprox 95mm must go Then you nead aprox 55mm of the Auto Bellhousing - 1-3mm of adjustment shold not be flush when welding i prefere 1mm gap. Her you can also see the Hub that is screewd down to the Crank shaft New pilot bering is neeaded to 6002 fits right on then its just to start welding it all toghether 4-5cm at the time and when the outside is done its tim for the inside. all done also i got a set of used 17inch oem wheels 8" front 9,5" rear Those will work better with my Euro Brakes. Edited January 19, 2013 by mattsson (see edit history) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 30, 2012 Share Posted December 30, 2012 Nice work mate you certainly dont hang about good enthusiasm Quote Link to comment Share on other sites More sharing options...
David P Posted December 30, 2012 Share Posted December 30, 2012 (edited) Thank you for posting the W59 upgrade pic. Nice job on the bell-housing, I hope it proves to align well. When it does, you're going to be a busy man knocking those out. You're lucky you're so far away, or I'd be visiting with pieces of aluminium castings for you to weld together. Edited December 30, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
basaez Posted January 1, 2013 Share Posted January 1, 2013 Very nice work mate !!! congrats!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
mattsson Posted January 1, 2013 Author Share Posted January 1, 2013 Thanks Today i hawe removed all the interior hawe orderd a new carpet from stockinteriors.com that just cleard customs so im going to put that in more picures as work continue Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 2, 2013 Share Posted January 2, 2013 Fantastic mate! Love your work. Quote Link to comment Share on other sites More sharing options...
mattsson Posted January 14, 2013 Author Share Posted January 14, 2013 (edited) Some Spedparts AN8 Fragola and a fuel filter Also baut a Oil cooler that i will feed froma Whaler Thermo block from a Volvo B230ET Red block in my opinion Termostat on the oil is verry important so you reach oil temp fast and then hawe a stabel temp. Pressure plate from Sachs 999 765 Flywheel from Comp Clutch Still wating for my 6puck Sprung hub from Clutchnet The Carpet from Stockinteriors is nothing i can recomend. Buy a OEM insted ! its made out off good material but they mould it directly on the floor without evening out the floor befor with some fome. Edited January 19, 2013 by mattsson (see edit history) Quote Link to comment Share on other sites More sharing options...
mattsson Posted January 19, 2013 Author Share Posted January 19, 2013 Parts from Elmhust thanks to Curt Quote Link to comment Share on other sites More sharing options...
Jos Posted January 19, 2013 Share Posted January 19, 2013 EGood work! I asume you bought a Lhd indicator and wiper selector switch, was it very expensive? Quote Link to comment Share on other sites More sharing options...
SpeedyAndy Posted January 20, 2013 Share Posted January 20, 2013 reading through this and the amount of work you have done, fair play. great pic's to show your work too Quote Link to comment Share on other sites More sharing options...
mattsson Posted January 20, 2013 Author Share Posted January 20, 2013 (edited) EGood work! I asume you bought a Lhd indicator and wiper selector switch, was it very expensive? it was 262$ in US at Elmhurst in Sweden They are twice that price or more im trying to sorece a LHD Wiper Crowl Cover the price in Sweden is over 500£ and 150£ in Us but shipping is expensive from Us so it makes no diffrence... Somone sitting on one and wold like to shipp it to sweden pls let me know I hawe a freindes addres in Dodrecht NL that is possible to send to if its cheaper than direct to Sweden Thanks evryone fore the positve response Edited January 20, 2013 by mattsson (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest suprark Posted February 8, 2013 Share Posted February 8, 2013 you ot some really nice stuff going in ther ;D Quote Link to comment Share on other sites More sharing options...
Guest suprark Posted February 8, 2013 Share Posted February 8, 2013 hi mate iv got one of thes bmw gearboxes for cheap money is yours runing allready how does it feel? Quote Link to comment Share on other sites More sharing options...
mattsson Posted February 11, 2013 Author Share Posted February 11, 2013 (edited) this is what i hawe done today in my lathe 34rpm it was 0.8mm off it moves slow right now Edited February 11, 2013 by mattsson (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted February 11, 2013 Share Posted February 11, 2013 (edited) Fabulous work, I can see lasers in your eyes. I think you should knock-up a 100 whilst your jigged up for the job. Edited February 11, 2013 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
mattsson Posted February 25, 2013 Author Share Posted February 25, 2013 Thanks now i will not make annything on the car since i hawe had surgery to my leg for the third time in since 2009 ... so the season will be short just hope to be able to run it in the end of this year Quote Link to comment Share on other sites More sharing options...
