listy Posted September 10, 2012 Share Posted September 10, 2012 that must be a straight bit of clear road to get a N/A to 123mph Does an NA get to 123mph??? Now the suprastick is sorted, get that supercharger on Dave, and get a vid up already. I'm itching to see this finished now Quote Link to comment Share on other sites More sharing options...
David P Posted September 10, 2012 Author Share Posted September 10, 2012 The supercharger and charge-cooler go on today and the bonnet will get a big hole instead of vents, the electrickery should be sorted tomorrow. Quote Link to comment Share on other sites More sharing options...
listy Posted September 10, 2012 Share Posted September 10, 2012 Quote Link to comment Share on other sites More sharing options...
David P Posted September 10, 2012 Author Share Posted September 10, 2012 (edited) The MkII rocker-cover is leaking, it will have to do for now but I need to find a solution for this. It's a waste of time modifying another old cover, a new one should be easier to weld but would crack on the top as it cooled just the same. Noz, This could be your finest hour. Could you laser-scan one and then set a machine about a hunk of aluminium, or make a mould and cast one, or a better idea even? http://www.mkivsupra.net/vbb/attachment.php?attachmentid=157318&d=1346961853 Noz, I haven't been able to find a cover that fits, could you please look into my request. It may be possible to machine a base plate and weld on the remainder? Let me know what you could do? Edited September 10, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted September 10, 2012 Author Share Posted September 10, 2012 I am getting tired of taking the n.s. rocker cover off. This is what I found, the plastic metal has excellent adhesion to the alloy yet had cracked over the joins. Using my old toothbrush, scrubbed twice with petrol then another twice with methanol and then given a good blathering with a flexible friend. It now has another two chances. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 10, 2012 Share Posted September 10, 2012 Yes, that looks `orrible enough to work David PITA welding used castings that have oil in them. The welds always go porous, especially when it's the *Hit they make things like cam covers from. Quote Link to comment Share on other sites More sharing options...
David P Posted September 10, 2012 Author Share Posted September 10, 2012 (edited) I have found that the injector clips supplied by Precision don't fit properly in situ, that puts and end to the 2 hour supercharger fit. The spring steel clips need a mm or two grinding off the ends. Edited September 10, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Steve Posted September 10, 2012 Share Posted September 10, 2012 that must be a straight bit of clear road to get a N/A to 123mph Does an NA get to 123mph??? Now the suprastick is sorted, get that supercharger on Dave, and get a vid up already. I'm itching to see this finished now I keep forgetting the n/a needs a long bit of road to hit those speeds, especially Davids with the longer gearing. Glad to help out again though David Quote Link to comment Share on other sites More sharing options...
Noz Posted September 10, 2012 Share Posted September 10, 2012 Does an NA get to 123mph??? When mines back on the road we use your speedo if you follow me to see how fast my little NA goes Quote Link to comment Share on other sites More sharing options...
David P Posted September 10, 2012 Author Share Posted September 10, 2012 (edited) Here's a pic of the N/A loom opened up to splice in the resistor pack, unlike a T.T. loom, 3 of the the injector earth-wires have to be accessed in the under-manifold casing. I will finish the electrickery tomorrow, the weather today has included strong wind, which is taking heat away from the solder joints. The injector clips didn't engage and needed adjusting with an angle-grinder for a proper fit. Mk 2.2 rocker-cover is fitted, supercharger mounted, top-idler and belt fitted, new 550cc low-impedance injectors and tails fitted, charge-cooler brackets mounted and vacuum pipes in place. Tonight and tomorrow morning is forecast rain. Edited September 10, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
listy Posted September 10, 2012 Share Posted September 10, 2012 Looking good due Quote Link to comment Share on other sites More sharing options...
David P Posted September 11, 2012 Author Share Posted September 11, 2012 Today is just as windy and to get the solder to run I'm having to use 2 electric soldering irons held like chopsticks. My home-made resistor-pack has had to go here, it's the only place there's space for it in the bay. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted September 11, 2012 Share Posted September 11, 2012 That's where the uk one goes. If its the same kinda thing. Quote Link to comment Share on other sites More sharing options...
David P Posted September 11, 2012 Author Share Posted September 11, 2012 (edited) If I'd known that I could have stolen yours. Edited September 11, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted September 11, 2012 Author Share Posted September 11, 2012 It's all back on again and the electrickery is organised, I hope it stay's on this time because the wiring would be a wind-up to revert. The rear of the installation is now tidier and easier to work with. The Mad Max deed is done. I will tinker with the ECU and fire it up tomorrow. Quote Link to comment Share on other sites More sharing options...
mark newman Posted September 11, 2012 Share Posted September 11, 2012 looks fun. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 11, 2012 Share Posted September 11, 2012 Good to see her back together hopefully you have more luck this time around. Cant believe you bought that bonnet to do that to it though Are you planning on having it joined together somehow so it just has a bulge, or some sort of vent? Quote Link to comment Share on other sites More sharing options...
Noz Posted September 11, 2012 Share Posted September 11, 2012 looking good. i assume tuning tomorrow? what time? il call you again mate? Quote Link to comment Share on other sites More sharing options...
David P Posted September 11, 2012 Author Share Posted September 11, 2012 Good to see her back together hopefully you have more luck this time around. Cant believe you bought that bonnet to do that to it though Are you planning on having it joined together somehow so it just has a bulge, or some sort of vent? I will make a mould to form a bulge and glass it on. looking good. i assume tuning tomorrow? what time? il call you again mate? Rolling road is on Thursday 13th, tomorrow I will set it up enough to drive it there. Quote Link to comment Share on other sites More sharing options...
Noz Posted September 11, 2012 Share Posted September 11, 2012 how u driven it without mappage? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 11, 2012 Share Posted September 11, 2012 I will make a mould to form a bulge and glass it on. Good plan, think it should look nice once done, not to OTT. You leaving the front vent on the bonnet too? Quote Link to comment Share on other sites More sharing options...
David P Posted September 11, 2012 Author Share Posted September 11, 2012 (edited) how u driven it without mappage? I will write it a simple one to get me there. Edited September 11, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Noz Posted September 11, 2012 Share Posted September 11, 2012 Risk it for a bisuit. You da man! Quote Link to comment Share on other sites More sharing options...
David P Posted September 11, 2012 Author Share Posted September 11, 2012 Good plan, think it should look nice once done, not to OTT. You leaving the front vent on the bonnet too? No that's going, but not yet because there would be almost no bonnet left. Quote Link to comment Share on other sites More sharing options...
David P Posted September 12, 2012 Author Share Posted September 12, 2012 (edited) Strong winds and fine rain with intermittent heavy showers are not friends of extension cables, battery chargers, electric soldering irons or my Workshop Manual. A couple of (if I had any) hair frizzing belts and I am soaked to the skin yet again. It turns out that the brand new AEM MAP sensor is a dud and because of this it cannot be driven. I will organise trailer transport for the morning. What a wind-up of a day. Edited September 12, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
