Supragaz Posted January 12, 2007 Share Posted January 12, 2007 I have a Concept300 and need to make it less sensitive. It keeps going off when cars go past mine at speed. I have been told I can change the sensitivity using the keyfob. Anyone know what I need to do please? If not I think the neighbours are gonna start keying my car soon!!! Thanks Gaz Quote Link to comment Share on other sites More sharing options...
Lewis Posted January 12, 2007 Share Posted January 12, 2007 Use the owners guide mate: http://www.clifford.com/guides/other.asp Quote Link to comment Share on other sites More sharing options...
Supragaz Posted January 12, 2007 Author Share Posted January 12, 2007 Thanks mate, having a 'blonde' moment!!! Quote Link to comment Share on other sites More sharing options...
Supragaz Posted January 12, 2007 Author Share Posted January 12, 2007 Checked the user manual and probably being a complete tool here but couldn't find a way to 'de-sensitise' my alarm. Could only find how to disable the proximity sensors for the inside. Anybody have an idea or had to do this before? Quote Link to comment Share on other sites More sharing options...
hadyn Posted January 12, 2007 Share Posted January 12, 2007 my intelliguard keeps going off at random too. Clifford really are shite alarms. Quote Link to comment Share on other sites More sharing options...
Supragaz Posted January 12, 2007 Author Share Posted January 12, 2007 True, but doesnt help my predicament Quote Link to comment Share on other sites More sharing options...
toyotasuprauk Posted January 12, 2007 Share Posted January 12, 2007 my intelliguard keeps going off at random too. Clifford really are shite alarms. I've heard a lot of people say that. Sorry doesnt help you much I know! How about calling a clifford installer tomorrow they should be able to tell you. Quote Link to comment Share on other sites More sharing options...
Supragaz Posted January 12, 2007 Author Share Posted January 12, 2007 I've heard a lot of people say that. Sorry doesnt help you much I know! How about calling a clifford installer tomorrow they should be able to tell you. Yeah I know, cheers dude. My mate is having a 650 fitted next week so will sort it then. The neighbours will have to put up with it going off loads in the mean time Quote Link to comment Share on other sites More sharing options...
Tourniquet Posted January 12, 2007 Share Posted January 12, 2007 My 300 is getting ripped out as soon as I can afford something else. Biggest pile o shit I've ever had. Goes off by itself (continuously) even after checking itself for problems and finding none and recently the fcuking thing won't un-arm so I've been stuck out of my car. When it does let me in or I unlock the door and wait for it to decide to let me turn the siren off and start the car...it then won't lock when I get where I'm going. No lie the best alarm I've ever had is a happy shopper £200 Laserline from Halfords on my old MkiV Escort 1.4l. Did it's job well and stopped it getting broken into and stolen on seperate occasions ! Quote Link to comment Share on other sites More sharing options...
markymark Posted January 13, 2007 Share Posted January 13, 2007 If it is anything like the concept 650 I have the instruction's for that? Read the following instructions thoroughly for a full understanding of how to properly adjust this sensor. 1. Disarm system 2. Transmit Channel 16. (Press cliff 3 times then * 1 time) . The LED will turn on and the siren will chirp 1 time. . Primary (full trigger) zone adjustment has now been entered. . Primary zone can now be adjusted. 3. Adjusting Primary Zone . Press (trunk) of the remote control to increase sensitivity. . Press (*) of the remote control to decrease sensitivity. . The sensor Primary zone can be tested at any time during adjustment and will generate 1 siren chirp each time the zone is activated. 4. Press (**) to adjust Warn-Away zone . Siren chirps 1 time. . Warn-away Zone adjustment has now been entered. . Warn-away Zone can now be adjusted. 5. Adjust Warn-away Zone . Press (trunk)to increase sensitivity. . Press (*)to decrease sensitivity. . The sensor Warn-away zone can be tested at any time during adjustment and will generate 1 siren chirp each time the zone is activated. 6. Press (lock/unlock) of the remote control to return to Primary zone adjustment and lock in Warn Away zone setting. . Siren chirps 2 times . Primary zone can now be re-adjusted as described in step 3. . Or press (lock/unlock) again to lock in primary zone setting and exit programming mode. . The siren will chirp 3 times when sensor adjustment mode has been exited. . Auto-Scroll for adjusting sensitivity - press and hold (trunk) or (*) to increase or decrease sensitivity setting several levels rapidly. Quote Link to comment Share on other sites More sharing options...
Supragaz Posted January 13, 2007 Author Share Posted January 13, 2007 If it is anything like the concept 650 I have the instruction's for that? Read the following instructions thoroughly for a full understanding of how to properly adjust this sensor. 1. Disarm system 2. Transmit Channel 16. (Press cliff 3 times then * 1 time) . The LED will turn on and the siren will chirp 1 time. . Primary (full trigger) zone adjustment has now been entered. . Primary zone can now be adjusted. 3. Adjusting Primary Zone . Press (trunk) of the remote control to increase sensitivity. . Press (*) of the remote control to decrease sensitivity. . The sensor Primary zone can be tested at any time during adjustment and will generate 1 siren chirp each time the zone is activated. 4. Press (**) to adjust Warn-Away zone . Siren chirps 1 time. . Warn-away Zone adjustment has now been entered. . Warn-away Zone can now be adjusted. 5. Adjust Warn-away Zone . Press (trunk)to increase sensitivity. . Press (*)to decrease sensitivity. . The sensor Warn-away zone can be tested at any time during adjustment and will generate 1 siren chirp each time the zone is activated. 6. Press (lock/unlock) of the remote control to return to Primary zone adjustment and lock in Warn Away zone setting. . Siren chirps 2 times . Primary zone can now be re-adjusted as described in step 3. . Or press (lock/unlock) again to lock in primary zone setting and exit programming mode. . The siren will chirp 3 times when sensor adjustment mode has been exited. . Auto-Scroll for adjusting sensitivity - press and hold (trunk) or (*) to increase or decrease sensitivity setting several levels rapidly. Thanks mate Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 4, 2007 Share Posted February 4, 2007 Thanks Mark, that's perfect bud! Quote Link to comment Share on other sites More sharing options...
