new washer wiper blades fitted
lockys96
took you an hour to fit- ? surely its a 2 min job:search:
set up your camera next to the car and ill time you then.
you do know you have to,
disconnect the old wiper arms,
remove wipers,
fit new wipers,
feed tube down springs,
remove 6 screws, the rubber piece under the bonnet
remove the 12 anoying clips on the plastic part between the bonnet,
remove the plastic section.
cut new hose length,
connect t-piece etc.
then you have to refit the lot backwards.
post a video when your done lmao:rolleyes:
  • 2 years later...
