Chris Wilson Posted January 19, 2007 Share Posted January 19, 2007 I used to supply and fit lots of water injection systems to turbo cars, and I wouldn't dream of NOT having it on my own turbo engines, yet, of late, I see very few Supra TT's or singles with WI mentioned. Why is this? Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2007 Share Posted January 19, 2007 I think alot of cars have been setup to not actually need it. Some would prob see it as a nice to have rather than a requirement. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 19, 2007 Share Posted January 19, 2007 Given it's not an expensive mod, I'm surprised it isn't used more. Will be adding it to mine at some point and I have it on my MR2. Mind you, the IC location on an MR2 sucks so I needed to improve cooling, at least the Supra has an ideal location for the IC. Quote Link to comment Share on other sites More sharing options...
bondango Posted January 19, 2007 Share Posted January 19, 2007 Dunno Chris, A lot of people may think they are not pushing boost enough to warrant WI or WI/Meth injection. I agree it is something that is overlooked, especially with the quality and pricing of kits that are vailable statesside (i.e. cooling mist, snow performance etc) Sorry didnt know you done your own kits Chris, so cant comment on them. The US kits are getting more advance with features like progressive controllers etc etc and a basic budget kit costing around £130 delivered. One BIG factor often overlooked is that it benefits engines all power levels with its ability of Decoking and keeping carbon deposits to a bare minimum, ive been amazed how clean some engines have been that run WI when stipped down. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 19, 2007 Share Posted January 19, 2007 I think some worry about it running out, but it doesn't get used up that quick and its hardly difficult to keep an eye on. Quote Link to comment Share on other sites More sharing options...
jayssupra Posted January 19, 2007 Share Posted January 19, 2007 How much is water injection fitted Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2007 Share Posted January 19, 2007 In my mind most people do not really use WI properly. A decent WI system using 50/50 water/meth hooked into the ECU to tell when there is a fault should enable you to run more boost, more ignition advance and lean the fuel mixture out. All this added together should make a noticable difference. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 19, 2007 Share Posted January 19, 2007 Do you need to alter your mapping much to accomodate the WI ? Might add it before the final mapping session. Pretty sure the AEM can run WI too. Quote Link to comment Share on other sites More sharing options...
Homer Posted January 19, 2007 Share Posted January 19, 2007 All this added together should make a noticable difference. What difference does it actually make? Does it simply mean boost can be raised a little with less likelihood of det, or is it something that can be used for low boost applications too? (eg T67 at 1.2 bar) Also, is ECU control essential? Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 19, 2007 Share Posted January 19, 2007 What difference does it actually make? Does it simply mean boost can be raised a little with less likelihood of det, or is it something that can be used for low boost applications too? (eg T67 at 1.2 bar) Also, is ECU control essential? There is a 'possible' way of getting an emanage to control the water injection based on boost levels... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 19, 2007 Author Share Posted January 19, 2007 Here's an old post of mine on WI: Water injection serves 2 closely related functions on a turbo engined car. Firstly it cools the charge air temperature by utilising an effect known as the latent heat of evaporation. This property can be self demonstrated very easily. If you pour something that evaporates quickly like petrol on your hand it feels very cold. This is the rapidly vaporising spirit removing heat from your skin and bloodstream by the aforementioned process. By spraying a very finely atomised mist of water into the inlet of a turbo engine when under boost conditions the evaporation of the water into steam causes a temperature reduction in the air and fuel intake charge. A cold charge is less likely to be subject to detonation than a hot charge. A cool charge is also denser, able to carry more air and fuel mix per unit of volume. These 2 properties of water injection allow either less chance of detonation at a given boost, maybe allowing lower octane fuel to be used, or to allow a rise in boost pressure usage without detonation. These are very desirable goals for any modifier of a turbo engine, or one using an engine mapped to run on a higher octane fuel than generally available in the UK. Japanese import turbo cars for example. People ask whether squirting water into an engine causes corrosion. In fact this is not a problem, the combustion temperatures under boost ensure the water is turned instantly to steam and is ejected out of the exhaust. The water mist is injected only when high boost is sensed via a supplied pressure sensor switch. The basic combustion process of hydrocarbon fuels causes LOTS of water to be generated anyway, which is why cars not driven on regular long journeys will rust out a mild steel exhaust system from the INSIDE out. If water is added in the correct volume, via the supplied, calibrated jets, this is not a problem. Even when used alongside a larger or more efficient intercooler, or indeed when an intercooler is used in an application where one was not present as standard, water injection can and does increase charge cooling still further. Water can be stored either in the existing windscreen washer bottle or in a separate, dedicated, container. In cold conditions it is essential to add an anti freeze additive to the water to stop pump damage through freezing. Windscreen washer additive serves this purpose fine and the engine won't mind ingesting this solution at all. Or you can add neat methanol, which is usually the anti freeze additive in washer fluid anyway. Using a 50 / 50 percent by volume water / methanol mix will actually help increase the octane of the intake charge, as an added benefit. As a yet further advantage the latent heat of evaporation of methanol is extremely high. A win / win situation. It is not however obligatory to use methanol as an additive. All components of the water injection kit that are in contact with the fluid are stainless steel or able to tolerate water and methanol or screen washer additive without degradation. A properly set up system does not use a vast amount of water, in fact a modern car sized screen washer bottle used also for the water injection reservoir will suffice admirably. A water filter is included to keep any sludge out of the pump or jet. This should be checked regularly for contamination and blown out if residue is apparent within. Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted January 19, 2007 Share Posted January 19, 2007 I'm a big fan of WI and a dealer for them now since I started my business two years ago. We have a load of MR2 customers but most supra owners really dont care for it. Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2007 Share Posted January 19, 2007 With the added cooling from the water and the increase in octane with the meths you can increase boost and ignition advance beyond what is normally acceptable, both of these two factors are very good for producing torque and power. For proper use I would say map to it but then for what ever reason the water/meth is not injected you stand a high chance of blowing the motor, this is where you need safe guards in place on the ECU to lower the boost and retard the ignition. As for the AEM you could use the nitrous maps, at the flick of a single switch you increase the boost target and run ignition and fuel correction maps to maximise its potential but you need a way to detect failure. Most people when installing WI just use it to cool intake temps and activate it from a pressure sensor at approx 1bar as its alot safer and does offer an extra safety margin when pushing the motor. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 19, 2007 Share Posted January 19, 2007 I have WI but have not reinstalled since the rebuild yet.... the thing that worrys me about mapping my car with it is if i have a problem such as pump failure of it runs out of water and i damage the engine. Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 19, 2007 Share Posted January 19, 2007 With regards the Emanage.... I was asked by myself specifically not to disclose that information as I have doen alot of thinking around this and thats a bit unfair otherwise. I was going to use something like the VTEC/NVCS map. Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2007 Share Posted January 19, 2007 I have WI but have not reinstalled since the rebuild yet.... the thing that worrys me about mapping my car with it is if i have a problem such as pump failure of it runs out of water and i damage the engine. Thats exactly my point, most people just use it in a fashion that doesnt really matter if it fails, which is fine and does offer more safety, but when used properly the gains can be much higher. I am in the same boat as you. Chris should hopefully be installing my WI in a couple of weeks but have only planned it as an extra safety margin and not to gain power with mapping etc. Quote Link to comment Share on other sites More sharing options...
Pete Posted January 19, 2007 Share Posted January 19, 2007 What level of tuning are we talking about it being a decent benefit to? Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 19, 2007 Share Posted January 19, 2007 I have WI but have not reinstalled since the rebuild yet.... the thing that worrys me about mapping my car with it is if i have a problem such as pump failure of it runs out of water and i damage the engine. There might be a way of fitting something like a washer bottle sensor and a dash light. Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2007 Share Posted January 19, 2007 There might be a way of fitting something like a washer bottle sensor and a dash light. Aquamist offer a water line pressure sensor which would be best as this would cover pump failure as well as water running out. http://www.aquamist.co.uk/cp/806-425/806-425.html Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 19, 2007 Share Posted January 19, 2007 Thats exactly my point, most people just use it in a fashion that doesnt really matter if it fails, which is fine and does offer more safety, but when used properly the gains can be much higher. I am in the same boat as you. Chris should hopefully be installing my WI in a couple of weeks but have only planned it as an extra safety margin and not to gain power with mapping etc. Yea i think ill reinstall mine after all the mapping is finished... just as a bit of extra help. Quote Link to comment Share on other sites More sharing options...
Homer Posted January 19, 2007 Share Posted January 19, 2007 Great post Chris, that explains the benefits and reasons for WI clearly.. at least on an engine thats designed to deliver maximum power. One thing thats not clear is why someone with a 'more than sufficient' fueling setup and map, plus running low boost on a 2JZ would require one. If the EGT and AFR measures are within safe limits then why add WI, surely there's no need? Quote Link to comment Share on other sites More sharing options...
Pig Posted January 19, 2007 Share Posted January 19, 2007 Yet again, roughly how much is one of these set up? Why will you only be running 1.2 homer? Edit sorry for off topic Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 19, 2007 Share Posted January 19, 2007 Yet again, roughly how much is one of these set up? Why will you only be running 1.2 homer? Edit sorry for off topic I got mine from this guy. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120024926370&ssPageName=MERC_VI_RSCC_Pr4_PcY_BIN_Stores_IT&refitem=120074444499&itemcount=4&refwidgetloc=active_view_item&usedrule1=StoreCatToStoreCat&refwidgettype=cross_promot_widget Quote Link to comment Share on other sites More sharing options...
b_have Posted January 19, 2007 Share Posted January 19, 2007 Wouldn't be without it. Stripped mine last year after 5 years of running single and it looked almost new. NO carbon and absolute zero det on any piston/squish. (always run 70% IPA or meth with water) Quote Link to comment Share on other sites More sharing options...
Homer Posted January 19, 2007 Share Posted January 19, 2007 Why will you only be running 1.2 homer? Stock bottom end Quote Link to comment Share on other sites More sharing options...
