evinX Posted April 25, 2010 Share Posted April 25, 2010 Hi all, my 3 speedos on the dash and auto shifter dont illuminate with the lights anymore, so when im driving at night i cant see my speed/petrol/selected gear, which is really an issue for me. Been sorting all my supras electrical problems recently but this one remains, dimmer switch dosent work either, found a blown 10 amp fuse in the footwell, replaced it but still nothing. Any help will be great! Thanks, Kevin Link to comment Share on other sites More sharing options...
Spike3.0 Posted April 25, 2010 Share Posted April 25, 2010 Check engine fuses bay too... Link to comment Share on other sites More sharing options...
evinX Posted April 25, 2010 Author Share Posted April 25, 2010 Check engine fuses bay too... Ah forgot to mention i also did the engine fuse box, also nothing, all are fine, maybe mine is missing and i dont know? any one got wiring diargams for the speedo cluster and auto shifter unit? or fuse locations? Kev Link to comment Share on other sites More sharing options...
evinX Posted April 26, 2010 Author Share Posted April 26, 2010 Someone please helllllp Link to comment Share on other sites More sharing options...
jimmenico Posted April 26, 2010 Share Posted April 26, 2010 have you removed the speedo unit and checked the bulb hasn't blown (or just replace the bulb and see)?? Link to comment Share on other sites More sharing options...
evinX Posted April 26, 2010 Author Share Posted April 26, 2010 acutally thats an idea! thank you mate:) if a light blew in the cluster could that do the auto selcter in to? Link to comment Share on other sites More sharing options...
evinX Posted April 27, 2010 Author Share Posted April 27, 2010 Can mods move this to technical, maybe more options will pop up in there:) Link to comment Share on other sites More sharing options...
pistonbroke Posted April 27, 2010 Share Posted April 27, 2010 If your dimmer doesn't work, my money is on that being the problem. Though I suppose all three bulbs could have blown if you're really unlucky. Link to comment Share on other sites More sharing options...
evinX Posted April 27, 2010 Author Share Posted April 27, 2010 ok ill have a look at that tomorrow:) Link to comment Share on other sites More sharing options...
mathew Posted April 27, 2010 Share Posted April 27, 2010 im glad you added a pic and circled the problem areas as i was really struggling trying to think where the speedo, petrol guage and the gear selector were. Link to comment Share on other sites More sharing options...
evinX Posted April 27, 2010 Author Share Posted April 27, 2010 Actually i just wanted to show of my interior. Link to comment Share on other sites More sharing options...
mathew Posted April 27, 2010 Share Posted April 27, 2010 Actually i just wanted to show of my interior. Link to comment Share on other sites More sharing options...
sams Posted April 27, 2010 Share Posted April 27, 2010 Does your interior light work? Link to comment Share on other sites More sharing options...
evinX Posted April 27, 2010 Author Share Posted April 27, 2010 Link to comment Share on other sites More sharing options...
evinX Posted April 27, 2010 Author Share Posted April 27, 2010 Does your interior light work? it never used to so that was rewired a long time ago, but the cluster and shifter used to light back then Link to comment Share on other sites More sharing options...
sams Posted April 27, 2010 Share Posted April 27, 2010 Well the interior light and shifter lights run on the same loom and same fuse in the enginebay fuse box, but your dash light I would point my finger at the dimmer switch Link to comment Share on other sites More sharing options...
Nicolai Posted April 27, 2010 Share Posted April 27, 2010 If the dimmer switch isnt working, the rest wont work either. Had the same problem. Link to comment Share on other sites More sharing options...
evinX Posted April 27, 2010 Author Share Posted April 27, 2010 If the dimmer switch isnt working, the rest wont work either. Had the same problem. ok ill strip the dimmer unit down and rebuild it, resolder the joints etc...maybe the bolts not tight enough...thanks peeps Link to comment Share on other sites More sharing options...
Wazz72 Posted May 1, 2010 Share Posted May 1, 2010 I'd put my money on the dimmer switch being faulty. Link to comment Share on other sites More sharing options...
