dash master warning light ?
lovatt
i know this has been done to death but i cant find what i am looking for in the search
since i fitted my HKS BOV a couple of days ago i have had the master warining light in the center of the dash come on a couple of times. i dont think i have knocked anything off and everything looks to be fitted correctly. the car feels no diffarent. its not fuel cut as i know what this feels like and my brake fluid is nice a full. what should i check as i have no manual to see what it could be ?
The general warning light should always have another light come on at the same time.
If you short the pins on the diagnostic port like described on Mkiv.com then it'll tell you the last error it recorded. It'll at least give you an indication of what it thinks is wrong.
I've seen this come on and off intermittently a few times, and everytime it's because of the brake fluid level (once in the NA, twice in the TT), which usually has the handbrake icon on at the same time.
Guest Martin F
Make sure the doors and boot are closed tightly. This can cause intermittant indication and no error codes will be recorded. Admittedly you should be able to see the door open indicator on the dash but it tends to be hidden behind the steering wheel when driving along.
not really a flicker, stays on for about 6 seconds, and its usually when i am coming to a stop, the brake fluid level looks good but i am going to top it right up to make shure its not that, thanks for the ideas guys, hopefully i will be able to let you know what it was after the weekend :( !
  • 7 months later...
Guest wglennie
I have a constant master warning light on and Toyota advise me that the error number is 42 but as it was a JAp import, they didn't know how to fix it - somthing to do with speed sensor. My auto spolier at the front has been disconnected,as I have a blitz spolier on the front. I sthis related? How do I fix it ??
Guest wglennie
Thanks Mark & Scooter for your posts. Just to be clear, the active spoiler has been removed and therefore I'm guessing the ECU thinks there is a issue with it and I need to understand how I tell it to ignore any alerts from it.
