cainhead Posted December 20, 2008 Share Posted December 20, 2008 Sorry if this is a silly question, but. Anyone know how to test an 02 sensor to see if its still working. Quote Link to comment Share on other sites More sharing options...
Dan8 Posted December 21, 2008 Share Posted December 21, 2008 if your milage is about 60k then change them anyway if theres alot of deposits around them you can soak them in a cleaner or lemon lemon juice i use universal sensors from ebay bosch Quote Link to comment Share on other sites More sharing options...
Dave17 Posted December 21, 2008 Share Posted December 21, 2008 Ditto above. They're cheap enough that its probably worth just getting a new one, easy to install as well! Quote Link to comment Share on other sites More sharing options...
bondango Posted December 22, 2008 Share Posted December 22, 2008 This should be in technical section. To test the sensor, start the engine and let it warm up Bridge out terminals TE1 and E1 on the diagnostics port Connect a multimeter (non digital is best) between the VF1 and E1 terminals of the diagnostics port. With the engine held at 2000rpms the Multimeter should fluctuate back and forth more than 8 times in 10 secs Any slower and the sensor needs replaced. Quote Link to comment Share on other sites More sharing options...
