How do you reset the ECU?
osso
Hi Guys
Whats the best way to reset the ECU on a JSpec Supra? bearing in mind that i've got a Clifford Concept 600, is there an ECU fuse in the engine bay that i can simply removed, or is there more to it than that?
Seem to remember on the MR2 Gt Turbo you had to remove the ECU fuse and the Fuel thingy fuse (cant remember what it was), to reset the ECU
Cheers
James
:conf:
There are only 1 fuse box in the engine bay that i am aware off, the one next to the battery. i cant see any mention of an ECU fuse on the back of that box.. the other box is a relay box for the ABS and TRAC ECU and that is on the otherside near the Air filter...
