edge Posted April 3, 2008 Share Posted April 3, 2008 Used these guys more than a few times now and have had great service every time. Rang yesterday morning and when i got home today i see some 6 speed gearbox oil waiting for me Thanks lads:thumbs: Quote Link to comment Share on other sites More sharing options...
colsoop Posted April 3, 2008 Share Posted April 3, 2008 Used these guys more than a few times now and have had great service every time. Rang yesterday morning and when i got home today i see some 6 speed gearbox oil waiting for me Thanks lads:thumbs: What oil did you go for ? Quote Link to comment Share on other sites More sharing options...
edge Posted April 3, 2008 Author Share Posted April 3, 2008 http://www.redlineoil.com/products_gearlubricants.asp?categoryID=8 D6 atf. Quote Link to comment Share on other sites More sharing options...
supra dan Posted April 4, 2008 Share Posted April 4, 2008 isnt redline supposed to damage the seals? Quote Link to comment Share on other sites More sharing options...
edge Posted April 4, 2008 Author Share Posted April 4, 2008 isnt redline supposed to damage the seals? I spoke with guy at opie to confirm this but the reasearch i done revealed that it was redline heavy shock which contains limestone and other agents not so gearbox friendly. Guy said its good if you want to get rid of car with a knackered gearbox. But the D6 is good stuff and safe to use. Another forum i see mentioned that the 160 box had a label on the side from new saying use atf. Check the skyline forums also aswel as others and you will see. I will be sending him a sample of the V160 oil from my box when i change it so he will then confirm our beliefs. Quote Link to comment Share on other sites More sharing options...
supra dan Posted April 4, 2008 Share Posted April 4, 2008 Quote Link to comment Share on other sites More sharing options...
Geo Posted April 4, 2008 Share Posted April 4, 2008 Yeah these guys are brilliant, Always speak to Guy and he always gives good deals G. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 7, 2008 Share Posted May 7, 2008 Any update on Redline MTL oil, garage put it in mine Quote Link to comment Share on other sites More sharing options...
edge Posted May 7, 2008 Author Share Posted May 7, 2008 Any update on Redline MTL oil, garage put it in mine MTL? edit oh man trans fluid lube. EDIT - i used the D6 atf Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 7, 2008 Share Posted May 7, 2008 MTL? edit oh man trans fluid lube. Yeah seems good so far. http://www.redlineoil.com/products_gearlubricants.asp?categoryID=7 Synthetic Manual Transmission Lubricants My gear box seal is leaking, after 3-4 weeks havin it in, might be coincidence but dont want to take the chance Quote Link to comment Share on other sites More sharing options...
edge Posted May 7, 2008 Author Share Posted May 7, 2008 I didnt use that one. I used the D6 http://www.opieoils.co.uk/p-1024-redline-d6-synthetic-automatic-transmission-fluid.aspx Quote Link to comment Share on other sites More sharing options...
edge Posted May 7, 2008 Author Share Posted May 7, 2008 And have done about 400 miles so far and i changed the rear selector seal aswel before filling with the d6 as that was leaking but i will keep an eye on it. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 7, 2008 Share Posted May 7, 2008 i have done 5000 KM so far Quote Link to comment Share on other sites More sharing options...
edge Posted May 7, 2008 Author Share Posted May 7, 2008 i have done 5000 KM so far The box needs an atf. When they first came out some boxes said use atf on the side (only what i read on other supra forums). I will be sending opie oils my old v160 oil to have tested and hopefully confirm that the D6 is more than good enough. Is it leaking from the main seals or the selector one as thats common for going.? Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 7, 2008 Share Posted May 7, 2008 It might just be coincidence, wonder wha t difference is between ATF oils and the redline MTL Quote Link to comment Share on other sites More sharing options...
edge Posted May 7, 2008 Author Share Posted May 7, 2008 It might just be coincidence, wonder wha t difference is between ATF oils and the redline MTL Give guy a ring at opie and he will be the best one to explain it to you i think. Quote Link to comment Share on other sites More sharing options...
