steve0 Posted May 17, 2006 Share Posted May 17, 2006 hi folks i know this sounds silly but hows the right way to remove and refit the aerotop roof ive no stickers or instructions on mine so i havent really got a clue whats the right way to do it and where would i get the right tool for it as ive just been using an allen key and im quite sure your better with the tool thanks Quote Link to comment Share on other sites More sharing options...
supRo Posted May 17, 2006 Share Posted May 17, 2006 MVP were selling the roof key Quote Link to comment Share on other sites More sharing options...
steve0 Posted May 18, 2006 Author Share Posted May 18, 2006 any links Quote Link to comment Share on other sites More sharing options...
Dragonball Posted May 18, 2006 Share Posted May 18, 2006 Steve just give me a call mate The tool I have one here - and you get them from me or toyota mate - no need to go to bleedin USA Quote Link to comment Share on other sites More sharing options...
Ark Posted May 18, 2006 Share Posted May 18, 2006 You only need a 5mm hex bit on a screw driver - electric screw driver preferred for the lazy amongst us (me). With regards fitting, you need to do or undo the bolts in the order: front drivers side, front passenger side, rear passenger side, rear drivers side. Do them up gently in that order then go round again and torque them properly. Forget the central shoot-bolt - it makes naff all difference to the stability or weather-proofing, and is only for holding the roof down when parked up (assuming you slung it on quickly, and intend to remove it before driving away). Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 18, 2006 Share Posted May 18, 2006 You only need a 5mm hex bit on a screw driver - electric screw driver preferred for the lazy amongst us (me). With regards fitting, you need to do or undo the bolts in the order: front drivers side, front passenger side, rear passenger side, rear drivers side. Do them up gently in that order then go round again and torque them properly. Forget the central shoot-bolt - it makes naff all difference to the stability or weather-proofing, and is only for holding the roof down when parked up (assuming you slung it on quickly, and intend to remove it before driving away). so when Paul Walker flips the top off when driving along the highway in the fast and the furious that's a load of crap?!?! it's like i've been told Santa isn't real or something equally insane...tut. Quote Link to comment Share on other sites More sharing options...
Ark Posted May 18, 2006 Share Posted May 18, 2006 so when Paul Walker flips the top off when driving along the highway in the fast and the furious that's a load of crap?!?! it's like i've been told Santa isn't real or something equally insane...tut. I'm not even going to respond to that... DOH!! Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 18, 2006 Share Posted May 18, 2006 I'm not even going to respond to that... DOH!! thought you might say that Quote Link to comment Share on other sites More sharing options...
