whats the offset on standerd 16" alloys?
D8MOA
  Steviekid said:
This will actually bring the wheels 10mm outwards compared to the stock wheels. Are you sure you need spacers?
lol obviously not now!! i got told toyota's off set should be between 35-38?
there 8J all round
People always get offsets the wrong way round
Smaller the offset Number ( further the wheel sticks out )
A 50 offset will push the wheels right inside the Arches
Best offset for a Supra with aftermarket wheels is 35-38
with rims between 8.5 / 9.5 - 10in *bigger size on back)
Although I have 8.5 all round with no probs
225/40x 18 on front ( going bigger when they wear out)
265/35x18 on back
There has been a thread on this already about a week ago
  D8MOA said:
ahh so ime right! if i want my 40mm offset wheels to be in spec i will need 2mm spacers to bring it to 38mm?
I wouldn't put spacers on unless it's absolutely necessary. Depending on the design of the alloys the fronts will probably fit on but your going to be running quite narrow wheels at the rear so although the offset is lower than standard they still might not fit on.
forget spacers, they will wreck your wheel bearings, long term
Also worth mentioning the importance of the correct spigots inside the wheel ( plastic rings) these must be fitted and with the correct bore, otherwise whole weight of car is on studs and not Hubs, and you probably get wheel shake / vibration etc
