turbo .ar turbine housings... .63 .81 .95 back to back
Mike B
Just recived the housings in the post this morning so thought I would post a picture of the sizes. I have used the .95 and find it a bit laggy.
Housing at the front of the pic is .68 (non divided), behind that is the .81 (non divided) and then the .95 (divided).
I plan on fitting the .68 first.
Big difference in size between the .95 and the other two, no? :blink:
  • Replies 73
Posted Images
Thanks wez...
I pm'd michel, if no joy I will get on the phone tomorrow.
Either the fairies took it or someone "tidied it up"...
don't you just hate it when you lose something and have absolutely no clue? been looking all night.... the "it has to be here" mentality.
I am watching this thread with great interest. I was also quite shocked at the difference in size of the exhaust housing between divided and non divided. Whats the consensus of opinion here is the divided 0.95 going to produce better results than the undivided 0.68?? I am going to try and swap out my tubbie tomorrow using my existing 0.96 ar divided housing and existing 0.70 ar compressor side. We shall see if it feels any different.
The divided housing will 'appear' to be much larger due to the huge slug of metal that has to be slung into the housing to divide it. The non-divided housing doesn't need this so will by nature be much smaller in size.
It doesn't mean the internal volume of the housing is much smaller, but it will certianly look far larger from the outside.
The pics are a little misleading if you're drawing direct conculsions between the external volume and it's internal volume.
