Lambo Doors
leonv
Has anyone put these on their car? Are they as easy as they say?
Pros and cons please
Who says they are easy? The people who sell them I guess :complain: I've watched a few being fitted to Supras here and they are not easy at all. However it really depends on the quality of the kit, do not go for a generic cheap kit, as it will end up costing you 10 times any saving in added labour charges, cutting, welding and bodging trying to make it fit.
The only kits worth using are the ones specifically designed for the Supra, ideally from a Japanese supplier, they are not cheap, £1000+ for the kit but they are far less hassle to fit and should bolt straight on 'relatively' easy.
The tuners I use here have fitted a few now and recommend using the Borzoi Wing System kit, as they reckon this is the best design and the easiest to fit. See details HERE If you need a source for the kit give me a shout as I can get them here in HK.
If you go to [thread=38818]THIS THREAD[/thread] you can see one of the cars that they fitted, the kit on this was from the US and can be remotely operated so the doors open and lift automatically, which was apparently an absolute b*tch to fit :twak:
