O2 sensor + Idle control Clean
Pig
Im about to go and take off the O2 sensor on my uk spec to clean it.
I have searched and just want to check im right.
I simply un bolt the O2 sensor from the decat pipe follow the wire back and un clip it. Leave it in lemon juice over night to clean it.
Regard the idle control valve, here is the pic i have of it.
Is it just a case up take off and clean?
What do i clean it with?
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13939&d=1112558977
Carb cleaner or WD40, just to loosen any crap that has gunged up inside it. Some people just remove the pipe which runs to the inlet and spray little amounts inside while the engine is running. But better its to remove it because a visual check is always a good idea. I think steve stripped his down to find the diaphram was cracked which wouldnt off hepled his running lean problems.
The car wont idle properly. Its really lumpy and sometimes even cuts out! Im not sure what to do to sort it. I have just taken the O2 sensor out and i look to already be cleaned. (pheonix prob did it when doing the single conversion) However its not plugged into anything. and the end of the plug is also melted. I just plugged it in to where i think it goes (by the front of the engine, but it made no difference)
Any ideas for next moves??
As you've cleaned it out, reset the ECU so it can relearn the Idle control now the valve has been cleaned out. If afater a few hoirs of driving its the same, you may need to check the Throttle position sensor.
RE: o2 sensor not being plugged in.
Is the car running a wideband o2? some you can configure an output to mimic the factory 1volt o2 signal to the ECU hence doing away with the stock sensor.
Usually an unplugged o2 sensor will throw a code 21
Marty
Melted plug?? Plugs not in?? Have you got a close up picture Jon??
The O2 sensor you removed, did it have small holes in it and about 10-15mm thick?? Or was it about 5mm thin??
O2 Sensor
http://alflash.narod.ru/O2/388.jpg
Not a Toyota one, but this is roughly the size of a Cat Temp Sensor.
http://www.microlabinfo.com/images/products/103.gif
