Jim_1979 Posted November 17, 2006 Share Posted November 17, 2006 What is it?? I've seen people mentioning it loads and I've done a search, but can't actually find what it is. What I've sussed out so far is it's for people with autos and larger than stock turbos. Someone mind explaining what it is, what it does. How much and what is involved in getting it on the car? Is it built into a gearbox? Do you need to buy a special gearbox with it? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
CJ Posted November 17, 2006 Share Posted November 17, 2006 Have a look here Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 17, 2006 Author Share Posted November 17, 2006 so.... "Stall speed is the amount of engine rpm that can be attained at full throttle with brakes locked and transmission in gear before the driving wheels turn. The stall is only attainable if the brakes can hold the vehicle." so how much are they usually?? ... say if you were going for a T61 or T67 turbo? Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 17, 2006 Author Share Posted November 17, 2006 and am I right in thinking it basically helps you get off the line better? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted November 17, 2006 Share Posted November 17, 2006 Yes.... Quote Link to comment Share on other sites More sharing options...
tDR Posted November 17, 2006 Share Posted November 17, 2006 Assuming you have the grip available to utilise it... Not necessarily for a larger turbo equipped car either....... I have stock twins and a PI 4,000 stall. Most people think this is overkill but I get on fine with it Quote Link to comment Share on other sites More sharing options...
JohnA Posted November 17, 2006 Share Posted November 17, 2006 It can also make it a loud, hard-revving, overheating pig in everyday traffic situations. It's a balance (like everything automotive - engineering) The coin has two sides, you don't get something for nothing. Quote Link to comment Share on other sites More sharing options...
tDR Posted November 17, 2006 Share Posted November 17, 2006 It can also make it a loud, hard-revving, overheating pig in everyday traffic situations. It's a balance (like everything automotive - engineering) The coin has two sides, you don't get something for nothing. Can't say I've experienced any such issues John... Quote Link to comment Share on other sites More sharing options...
terribleturner Posted November 17, 2006 Share Posted November 17, 2006 The only issue i have is the lock up switch that i havn't installed, but that's coz it's all coming out soon. Quote Link to comment Share on other sites More sharing options...
Robbie Posted November 17, 2006 Share Posted November 17, 2006 I'm now officially a convert! It'll no doubt be interesting on the track and'll take a little getting used to but... Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 17, 2006 Author Share Posted November 17, 2006 so... how much are they usually? Quote Link to comment Share on other sites More sharing options...
absz Posted November 17, 2006 Share Posted November 17, 2006 The only issue i have is the lock up switch that i havn't installed, but that's coz it's all coming out soon. yeah get on with it:d Quote Link to comment Share on other sites More sharing options...
b_have Posted November 17, 2006 Share Posted November 17, 2006 Got mine from mkivstore around £550. They used to be over a grand! Quote Link to comment Share on other sites More sharing options...
Matt H Posted November 17, 2006 Share Posted November 17, 2006 But isnt a high stall just the same as getting your revs up and letting the clutch go. From what ive read, it seems that simply put, your car will be ideling closer to the powerband which means when you put your put down you will be off in the correct location. For Autos i can see the point, but not for manu transmission, altough having said that power braking is an alternative. Am i missing something? i did read something about the cars brakes? how does that work, does the torque convertor have some control over the braking which stops the car launching prematurely? If its doesnt then that would be ace! revs up, brakes on hard, car pulling but not enough to over power the brakes then...... boom, your off. Quote Link to comment Share on other sites More sharing options...
CJ Posted November 17, 2006 Share Posted November 17, 2006 A TC is part of the auto box mate - nothing to do with a manual car at all. Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 17, 2006 Share Posted November 17, 2006 No link to the brakes either... Quote Link to comment Share on other sites More sharing options...
Matt H Posted November 17, 2006 Share Posted November 17, 2006 A TC is part of the auto box mate - nothing to do with a manual car at all. oh yeah! silly me, so its either go for a higher stall TC or use power braking to get the revs up on launch? Would that be correct? Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 17, 2006 Author Share Posted November 17, 2006 what happens if you rev it a little in "N", then put it into "D" with the revs still on?? Quote Link to comment Share on other sites More sharing options...
CJ Posted November 17, 2006 Share Posted November 17, 2006 what happens if you rev it a little in "N", then put it into "D" with the revs still on?? You will soon be posting up asking for an auto box as cheap as possible Quote Link to comment Share on other sites More sharing options...
Matt H Posted November 17, 2006 Share Posted November 17, 2006 what happens if you rev it a little in "N", then put it into "D" with the revs still on?? I would suspect that you wouldnt get much out of doing that due to that little bit of time it takes for the transfer between N and D Quote Link to comment Share on other sites More sharing options...
Matt H Posted November 17, 2006 Share Posted November 17, 2006 You will soon be posting up asking for an auto box as cheap as possible U not gonna respond to my previous post mate Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 17, 2006 Author Share Posted November 17, 2006 You will soon be posting up asking for an auto box as cheap as possible lol.... so that's a no no then! Quote Link to comment Share on other sites More sharing options...
CJ Posted November 17, 2006 Share Posted November 17, 2006 oh yeah! silly me, so its either go for a higher stall TC or use power braking to get the revs up on launch? Would that be correct? Correct - but a higher stall TC would allow you to build higher revs when power braking. Quote Link to comment Share on other sites More sharing options...
Matt H Posted November 17, 2006 Share Posted November 17, 2006 Correct - but a higher stall TC would allow you to build higher revs when power braking. ah, yes, indeed it would! ta Quote Link to comment Share on other sites More sharing options...
terribleturner Posted November 17, 2006 Share Posted November 17, 2006 yeah get on with it:d Sorry Abs , Booked in for the 2nd of December so im sure it will be out the car on the Monday. Quote Link to comment Share on other sites More sharing options...
