Anyone know their supras in essex?
alaing
Sorry. Yeh some info would help. It a j-spec tt. totally standard, its not on the road yet either thanks.
First call is usually the coil pack connectors and wiring as well as checking the error codes. That said without a lot more information, it could be a multitude of things. Could be some pins loose on the ECU connector...could be lots....Can you describe it a bit more?
I used to have a missfire at the top end of the rev range, i thought ok, must be coil clips sure enough some of the coils didnt even have clips on them just the metal connectors pushed onto the coils! So i replaced the spark plugs, the clips, spark plug boots and checked all the wiring for breaks, loose wires, made the metal connectors sit on the coil terminals tighter etc.
I now seem to have a missfire in the bottom half of the rev range!!
If you stamp on the accelerator it will miss really badly then pick up at about 2k. On idle it will 'cough' every 20 sec or so. I took off the coil clips one at a time to try it narrow it down to a cylinder but although it misses on each cylinder when the clip is off it will still 'cough' every 20sec or so?! Like its missing on another cylinder aswell. But it does this on every one you disconnect. As you can imagine its very fustrating as it was fine before everything was changed (on idle i mean). Any ideas would be a big help.
alain
If you've removed one coil at at time, and the cough still occurs, then perhaps fuelling? Could it be the O2 sensor? I know that they can get clogged up and thus false readings, but I'm not sure if that would make more trouble than you have?
If it's bogging down with quick throttle opening, it sounds like not enough fuel?
Hmmm...
