Geezabloke Posted May 13, 2004 Share Posted May 13, 2004 OK plenty of you guys have now painted your dashes, have you any tips for removal of the rubberised original finsh prior to priming? Come on Paul E you must have found an easy way to do it?... Cheers Dave :flame Dev Link to comment Share on other sites More sharing options...
LeeT Posted May 13, 2004 Share Posted May 13, 2004 i need to do mine as well but it seems there's no easy way. just use thinners and persevere with it. Link to comment Share on other sites More sharing options...
Aerotop Dave Posted May 13, 2004 Share Posted May 13, 2004 There's been a few threads on this - try a search for 'dashboard' or 'dashboard paint'. This thread might be of particular use: http://www.mkivsupra.net/vbb/showthread.php?s=&threadid=16935 Link to comment Share on other sites More sharing options...
Matt B Posted May 13, 2004 Share Posted May 13, 2004 Mate to be honest I gave up on the idea after all the trouble I heard it was. Don't call me a sissy but I just did not want it to look worse than it did to start with. Got it sprayed and it was well worth the money cos it looks fantastic I reckon. Link to comment Share on other sites More sharing options...
Dragonball Posted May 13, 2004 Share Posted May 13, 2004 Originally posted by Geezabloke Come on Paul E you must have found an easy way to do it?... Cheers Dave :flame Dev A bigger PITA I have never experieneced!! Took me an hour to prepare just the ashtray bit Ask Jake - he's good at it:p Link to comment Share on other sites More sharing options...
dangerous brain Posted May 15, 2004 Share Posted May 15, 2004 Right I did mine recently with fairly good results. The thing I found the most difficult was the spray painting. Getting the vulcanised rubber off wasn't too bad. I used neat acetone in a spray bottle. You do however have to be a bit carefull cos if you get over exuberant with the acetone you can melt the plastic underneath. Basically a big square of scotchbrite (plastic scouring pad of the green variety) with acetone (ie nail varnish remover) will shift the rubbery nastyness. After that for a good finish its up to you sort out the rubbing down. Link to comment Share on other sites More sharing options...
LeeT Posted May 15, 2004 Share Posted May 15, 2004 Originally posted by dangerous brain Right I did mine recently with fairly good results. The thing I found the most difficult was the spray painting. Getting the vulcanised rubber off wasn't too bad. I used neat acetone in a spray bottle. You do however have to be a bit carefull cos if you get over exuberant with the acetone you can melt the plastic underneath. Basically a big square of scotchbrite (plastic scouring pad of the green variety) with acetone (ie nail varnish remover) will shift the rubbery nastyness. After that for a good finish its up to you sort out the rubbing down. did you use aerosol? i wondered if the finish would be durable enough for the interior. if it is i will do mine next weekend:thumbs: . i suppose if it was kept in the airing cupboard overnight it would have the same effect as a spray shop oven Link to comment Share on other sites More sharing options...
dangerous brain Posted May 15, 2004 Share Posted May 15, 2004 (I used one of them plastic refillable spray cans)Edited to say for the acetone lol I just realised that you meant paint. Yes I used an aerosol paint. The finish is very durable but if you want it even more so use a laquer over the top as well. Be advised though I don't think you will manage the job in one weekend. Also I cooked all my panels in my oven at 60 degrees no problems (stank the house out mind). Near the end I was just pouring the acetone on but you have to be very carefull to not let it sit in a pool or it will start to melt the plastic underneath. If you can get hold of a sheet of perspex snap bits off and use the corners as scrapers, this works very well and cuts down on the amount of elbow grease required. If you get stuck drop me a PM and I will see what I can do to help fella. Link to comment Share on other sites More sharing options...
LeeT Posted May 15, 2004 Share Posted May 15, 2004 cheers DB will do. Link to comment Share on other sites More sharing options...
Geezabloke Posted May 15, 2004 Author Share Posted May 15, 2004 Right ... have got 99% of the F*cking rubber off........just got to decide on colour now.......Here we go again...lol Dave :flame Dev Link to comment Share on other sites More sharing options...
dangerous brain Posted May 17, 2004 Share Posted May 17, 2004 If you have coloured seats try and pick up a colour in those to match to. I did mine in the same red as my seats alcantara centres. Failing that mettalic/mica black looks good. I have seen a few done in silver which looks OK but I really wouldn't go with matching your exterior paint just my opinion. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 17, 2004 Share Posted May 17, 2004 i still got to come see this car DB must be beginning to look the nuts...i guess it beginning to go the nuts as well in summer i will have my dash off to do it, thinking blue and white interior for my car, as i have bought some blue interior neon lights Link to comment Share on other sites More sharing options...
dangerous brain Posted May 17, 2004 Share Posted May 17, 2004 Originally posted by whitesupraboy2 i still got to come see this car DB must be beginning to look the nuts...i guess it beginning to go the nuts as well in summer i will have my dash off to do it, thinking blue and white interior for my car, as i have bought some blue interior neon lights Blue??? Blue????? Stopit man!!! Before you know it you will have XR3i decals down the side and hoofing great spots fibreglassed into the bonnet with a big blue FORD emblem across it again!!!!! Actually though thats one thing ford did get right with those cars the blue/white mix is very good. The car is starting to come together quite nicely now. Getting the rear seats done and a little more work on the fronts in a couple of weeks. My genuine article Veilside skirts should be along in a day or two. Three weeks time the car goes to the spray shop to get the skirts painted and the dodgy 11 year old paintwork attended to. Then hopefully the insurance company will have sorted Hi-supes claim out and I will get me donor vehicle in time for my insurance renewal. If you are about this evening I might be tempted to take the wagon out for a blat to yours! Link to comment Share on other sites More sharing options...
Steve W2 Posted May 17, 2004 Share Posted May 17, 2004 I've done this as well and can say that it is a PITA but does look good after. Mine has been on for about 9 months without any problems or scratches. I used nail polish remover, a scouring pad, a 2p coin:D (seriously) 50p would perhaps be better and halfords paint and lacquer. I did mine metallic black in a silver car, painting it silver would be a bit too much for me. oh and PMSL and WSB2!! Can't wait to see those blue 'Supra' decals your getting down the side:D I am putting the silver 'Supra' logo for the brake caliper on my dash when I get round to finishing it:D Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 17, 2004 Share Posted May 17, 2004 hey im not gonna do that to the supra......yet actually DB i was hopeing u were around i fancied a drive im glad i didnt rush into changing my car...bumpers etc....i see so many styles, i would of probably been disapointed by now! P.s my past always catchs up! lol damn that escort, just as well no one ever saw the xr2i Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 17, 2004 Share Posted May 17, 2004 Originally posted by dangerous brain hoofing great spots fibreglassed into the bonnet is it wrong to like this idea??? Link to comment Share on other sites More sharing options...
dangerous brain Posted May 17, 2004 Share Posted May 17, 2004 Wrong diddley wrong wrong wrong!!!!!!! Link to comment Share on other sites More sharing options...
