garetheves Posted August 26, 2006 Share Posted August 26, 2006 Following on from this thread.... I finally got round to checking my spark plugs. Only problems is i havent got a clue what im looking for to see if they need replacing or not. Could someone please have a look at the photos below and give me your views. Each plug has 2 photos, 1 of the plug and coil pack and a 2nd of a close up of the plug. The photos are in the order the plugs are in the engine, ie the first 2 photos are the "front-most" plug, the last set of 2 are the furthest away. Hope that makes sense. Cheers guys. Quote Link to comment Share on other sites More sharing options...
merckx Posted August 26, 2006 Share Posted August 26, 2006 They don't look too bad, but they do look just a little old . I replace mine every 3-4k regardless, the ones Matt Harwood mentioned are only about £10.50 a set at Partco. At that price it's good practice to replace them regularly. They're good for the BPU car too. Quote Link to comment Share on other sites More sharing options...
Fifty Posted August 26, 2006 Share Posted August 26, 2006 Look Ok to me m8 but why not give her a new set anyway since youve bothered to take em all out? Rich Quote Link to comment Share on other sites More sharing options...
garetheves Posted August 26, 2006 Author Share Posted August 26, 2006 Is the oil around the coil packs fairly normal?? Quote Link to comment Share on other sites More sharing options...
garetheves Posted August 26, 2006 Author Share Posted August 26, 2006 They're good for the BPU car too. What about for a T61 though Quote Link to comment Share on other sites More sharing options...
merckx Posted August 26, 2006 Share Posted August 26, 2006 What about for a T61 though No problem. http://www.mkivsupra.net/vbb/showthread.php?t=41927 The oil will be coming from the cylinder head cover gaskets ,this isn't a problem unless it's excessive. It's very common to get a little oil leaking out. Quote Link to comment Share on other sites More sharing options...
garetheves Posted August 26, 2006 Author Share Posted August 26, 2006 I knew the plugs would be alright really. Good about the oil though. Ill buy some new plugs tomorrow i think. Quote Link to comment Share on other sites More sharing options...
absz Posted August 26, 2006 Share Posted August 26, 2006 plug 4 seems to have alot of dry water marks on and around the ceramic bit also the plug lead. you might be getting rain water entering from somewere. have you got a aftermarket bonnet ? Quote Link to comment Share on other sites More sharing options...
garetheves Posted August 26, 2006 Author Share Posted August 26, 2006 No, stock. Quote Link to comment Share on other sites More sharing options...
bromy Posted August 26, 2006 Share Posted August 26, 2006 I wait to be shot down, IMO they look a bit rich Quote Link to comment Share on other sites More sharing options...
LeeT Posted August 26, 2006 Share Posted August 26, 2006 what plugs are they out of interest? Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 26, 2006 Share Posted August 26, 2006 think it's time for some new plugs mate. Quote Link to comment Share on other sites More sharing options...
bromy Posted August 26, 2006 Share Posted August 26, 2006 what plugs are they out of interest? I was going to ask that, never seen that design before Quote Link to comment Share on other sites More sharing options...
LeeT Posted August 26, 2006 Share Posted August 26, 2006 I was going to ask that, never seen that design before They have to be either platinum or iridium with the small electrode but i was wondering what heat range he is running as he is single Quote Link to comment Share on other sites More sharing options...
garetheves Posted August 26, 2006 Author Share Posted August 26, 2006 Cant find a model number on them anywhere. They are NGK-R thats all i can tell you. They were on the car when i bought it so i dont know for deffinate. Ill have a look through the old receipts and see if theres anything there. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 26, 2006 Share Posted August 26, 2006 How long have they been in? they look like they are slightly to cold for the running conditions, ie a lot of soot and the centres are very dark brown, one or two of them also look a little oily, but i suspect that may be due to the oil that has leaked from the cam covers into the plug recess and in turn run down over the plug as you removed them. Quote Link to comment Share on other sites More sharing options...
garetheves Posted August 26, 2006 Author Share Posted August 26, 2006 The only documentation i can find on them says they are NGK 8 Plugs and were fitted in October 2003, so well overdue for a change if this was indeed the last change. Im sure they have been changed since then though. Its had a full service including Cambelt within the last year, surely they would have changed them then?? Quote Link to comment Share on other sites More sharing options...
