Elmo Posted August 29, 2007 Share Posted August 29, 2007 It has been established that the stock air box is better than a bolt on induction kit as it only allows cold air to be sucked into the throttle body. Thinking about this, would it be possible to adapt the stock air box (cut a hole in it) to accept the aftermarket induction tubing/filter, this way you are getting the best of both worlds or, would you? This may have been done or discussed before, but without looking deeper into it I don't see why it should work. Any thoughts? Quote Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted August 29, 2007 Share Posted August 29, 2007 I'd like to get rid of my Blitz SUS induction kit and replace it with the stock airbox too. As you say though, the piping for the FMIC gets in the way and the box would have to be heavily modified somehow. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 29, 2007 Share Posted August 29, 2007 I will be using a stainless steel airbox with my single kit, designed to sit in the same place and using a TRD panel filter. I will report on the outcome. Quote Link to comment Share on other sites More sharing options...
robin Posted August 29, 2007 Share Posted August 29, 2007 can you not get a panel filter to go in the stock box? I cant help but think if a filter flows more air is must have less filtration though... Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 29, 2007 Author Share Posted August 29, 2007 can you not get a panel filter to go in the stock box? I cant help but think if a filter flows more air is must have less filtration though... Yeah, I could. But I assumed that an aftermarket induction kit would give better airflow. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 29, 2007 Share Posted August 29, 2007 Yeah, I could. But I assumed that an aftermarket induction kit would give better airflow. Why? Why didn't Toyota use induction kits when designing the car? Because the stock system is more efficient? Quote Link to comment Share on other sites More sharing options...
colsoop Posted August 29, 2007 Share Posted August 29, 2007 Yeah, I could. But I assumed that an aftermarket induction kit would give better airflow. Perhaps better airflow but at the expense of filtration Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted August 29, 2007 Share Posted August 29, 2007 Stick with stock, Toyota have spent time and money developing these! Now on the other hand, Why not try a Piper-X Sponge one, i know they're good Quote Link to comment Share on other sites More sharing options...
Stevie Boy Posted August 29, 2007 Share Posted August 29, 2007 Yeah, I could. But I assumed that an aftermarket induction kit would give better airflow. I guess this would depend on if the surface area of the cone filter was greater than a stock panel filter area, otherwise I'd be suprised if it would flow anymore air than a stock. Quote Link to comment Share on other sites More sharing options...
dwayne Posted August 29, 2007 Share Posted August 29, 2007 anyone know which induction kit is best of the bunch? i currently have the hks but i think i'll be loosing that soon Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 29, 2007 Share Posted August 29, 2007 anyone know which induction kit is best of the bunch? i currently have the hks but i think i'll be loosing that soon Apexi is good if you have to have a cone but i'd buy the stock one for sale in the for sale section mate. It's the best my miles. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 29, 2007 Share Posted August 29, 2007 http://www.mkivsupra.net/vbb/showthread.php?t=122405 Quote Link to comment Share on other sites More sharing options...
Konrad Posted August 29, 2007 Share Posted August 29, 2007 Why? Why didn't Toyota use induction kits when designing the car? Because the stock system is more efficient? Maybe because some makes are from 2005 and Toyota had to put their system at 1993? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 29, 2007 Share Posted August 29, 2007 Maybe because some makes are from 2005 and Toyota had to put their system at 1993? Is that a way of playing devils advocate? It's been proved time and time again that the stock airbox is the best method of intake, including with some single installs. Quote Link to comment Share on other sites More sharing options...
tDR Posted August 29, 2007 Share Posted August 29, 2007 Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 29, 2007 Share Posted August 29, 2007 Thats a nice setup. I'm going for a similar idea but with panel filter Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 29, 2007 Author Share Posted August 29, 2007 http://img.photobucket.com/albums/v728/tdr1980/mkivsupra%20pics/DSC00012.jpg Does look good, sort of what I was thinking of. In your opinion is this better than stock? Quote Link to comment Share on other sites More sharing options...
Sharpie Posted August 29, 2007 Share Posted August 29, 2007 http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=213&SearchYN=N Quote Link to comment Share on other sites More sharing options...
Dave Posted August 29, 2007 Share Posted August 29, 2007 wheres the proof stock is better than cone .the two intakes for the stock are pants my apexi has the stock headlight feed and a 3in cold feed pipe direct from the outside straight on the filter.its shielded from the engine heat ,its more responsive especially in the cold and sounds better .so mines staying put Quote Link to comment Share on other sites More sharing options...
Sharpie Posted August 29, 2007 Share Posted August 29, 2007 So far, I have never seen any independent proper testing of any of the aftermarket filters or ANY filters……So why HKS get's slagged off above any other aftermarket filter, without any independent proper testing done on any of them, I don't know why. I don't count hoover tests... Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 29, 2007 Author Share Posted August 29, 2007 http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=213&SearchYN=N That looks good! I would have thought it would be fairly easy to make that heat sheild out of a sheet of Stainless Steel. Quote Link to comment Share on other sites More sharing options...
tDR Posted August 29, 2007 Share Posted August 29, 2007 Does look good, sort of what I was thinking of. In your opinion is this better than stock? Yes. And it is the "Max Air" kit Peter has posted the link to - just needs adapted a little because it's designed to fit the MAF equipped US / UK model rather than JDM Supra. Don't get me wrong, there's really not much wrong with the OEM airbox / filter and most aftermarket cone type setups are worse - it's just IMO this setup gives me the best of both worlds. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 29, 2007 Author Share Posted August 29, 2007 Yes. And it is the "Max Air" kit Peter has posted the link to - just needs adapted a little because it's designed to fit the MAF equipped US / UK model rather than JDM Supra. Don't get me wrong, there's really not much wrong with the OEM airbox / filter and most aftermarket cone type setups are worse - it's just IMO this setup gives me the best of both worlds. Cheers, Brian. As I said in my first post, do you think the standard air box can be modified if a hole was cut in it to make way for the induction tubing, and is there enough room inside the airbox for a cone? Quote Link to comment Share on other sites More sharing options...
Class One Posted August 29, 2007 Share Posted August 29, 2007 Bri, is the "box" part felxible enough to be fitted, ie the back plate that goes against the turbo to intercooler pipe ir is it rigid. You saw my set up at TOTB with the Greddy style foam filter but because my intercooler pipe to my fmic doesn't quite follow the stock routeing, I'm looking fior something better than what I have and I know my stock airbox won't fit back on. Because my car boosts better in colder air, I think I'm getting a bit of heat soak because after a bit of spirited driving it will struggle to get over 1 bar but in the cooler air of when the engine isn't hot it'll acheive 1.1bar easily. Quote Link to comment Share on other sites More sharing options...
tDR Posted August 29, 2007 Share Posted August 29, 2007 As I said in my first post, do you think the standard air box can be modified if a hole was cut in it to make way for the induction tubing, and is there enough room inside the airbox for a cone? Not really - you'd be better fabricating your own box. Quote Link to comment Share on other sites More sharing options...
