Remove steering wheel w/airbag
Matti85
yes and thats it, remove the bag you'll be able to see the big nut holding the wheel on there
Dont forget when you disconnect the battery to remove the negative terminal and then leave it for a good 10-15 mins as some componants can store a charge which may still let the bag go off.
Just got the tools and managed to remove the two star shaped screws, but bought wrong sizes at first so had to go change =).
Anyway, after i got them off i took out the airbag, and saw the big bolt in the middle, put some WD40 on it and it got out pretty easy.
But the F***R wont give up, there is nothing left holding the steering wheel, ive tryed to hammer it from behind and, plenty of WD 40 and still nothing, i almost past out when i gave it a final go, if someone had recorded me on a cam i would have won first price at candy cam haha.
I know they tend to get stuck after so many years, ´had one without airbag and it was hard to remove that as well after i got the bolt out, but this shit just takes the price, it wont move 1mm.
Will try tomorrow, put some more WD40 and will let if over night.
Did you had this nightmare as well, when removeing the steering ?
take off the bolt
then screw it back on 2or3 threads so when you pull off the wheel the bolt stops it rather than your nose :)
LOL, the first time i did that (on the other car, a wheel without airbag) it came right on my head, so this time i put on my dirtbike helmet =)
As i said, tomorrow ill ask a friend to record me on cam, i promise y ill get first price on candy camera, cuz this time ill go mental on that wheel.
