supra FTW Posted July 3, 2008 Share Posted July 3, 2008 hi im just about to do my oil chaing on my tt and am going to use lucas 10/40 and the addative that makes the oil better if you no what i mean. it says i ownly put a amount of addative in depending on the amount of oil the car uses i.e if the car takes 5L i use the whole bottle i did a serch but couldnt find how many liters of oil the 2jz takes...any ideas? many thanks Matt Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted July 3, 2008 Share Posted July 3, 2008 additive that makes oil better????? you should sell this to the oil companies you'll make millions......... Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 3, 2008 Share Posted July 3, 2008 if you no what i mean. Nope chaing; ownly; addative; serch; liters Hmmm.... There is no reason to add anything to the oil if you use the correct specification oil. Quote Link to comment Share on other sites More sharing options...
supra FTW Posted July 3, 2008 Author Share Posted July 3, 2008 how many litres of oil does the 2jz hold....was that slow enough for you:p Quote Link to comment Share on other sites More sharing options...
Alex Posted July 3, 2008 Share Posted July 3, 2008 DON'T DO IT!!!! Buy decent oil from the word go or sell the car. You need 5-6L's of GOOD oil. Silkolene Pro-S 10w50 or something else effective. Additives are full of BS only. Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 3, 2008 Share Posted July 3, 2008 Welcome to the power of search http://www.mkivsupra.net/vbb/showthread.php?t=28529&highlight=oil Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted July 3, 2008 Share Posted July 3, 2008 fill and check with good oil, don't just throw it all in at once, you really don't want to over fill the block, if i remember correctly it should be between 5 - 5.3l but it tends to vary, please don't use the snake oil:( Quote Link to comment Share on other sites More sharing options...
supra FTW Posted July 3, 2008 Author Share Posted July 3, 2008 i thought lucas was good/expensive oil? Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted July 3, 2008 Share Posted July 3, 2008 Welcome to the power of search http://www.mkivsupra.net/vbb/showthread.php?t=28529&highlight=oil good post, have a read of the above post, oil is the cars blood, only treat it to the best Quote Link to comment Share on other sites More sharing options...
Alex Posted July 3, 2008 Share Posted July 3, 2008 i thought lucas was good/expensive oil? If it's so good why on earth would you consider putting in "additives"?? Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted July 3, 2008 Share Posted July 3, 2008 i thought lucas was good/expensive oil? i always use Silkolene , i don't know how good the lucus oil is to be fair Quote Link to comment Share on other sites More sharing options...
supra FTW Posted July 3, 2008 Author Share Posted July 3, 2008 i understand silkoline is the bees neez but i thought lucas was a top oil aswel? im not disagreing with you. its hard to describe how it makes the oil better it just does thay have a display that showes how, has anyone ever used lucas and it realy made a mess of your motor?? or is this just all theory im not trying to be argumentative i would just like to no why and for what reson? Quote Link to comment Share on other sites More sharing options...
Thorin Posted July 3, 2008 Share Posted July 3, 2008 Which of their oils have you bought for a start? Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted July 3, 2008 Share Posted July 3, 2008 its not really the oil mate, its putting in additives, oil companies spend millions to get the 'edge' on the compatition, if this additive is so good how come none of the oil companies add it to their oil? for what its worth the Lucus oil is probably very good (although don't quote me on that) Quote Link to comment Share on other sites More sharing options...
Multics Posted July 3, 2008 Share Posted July 3, 2008 Just stick with Silkolene or Motul 300V Chrono. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 3, 2008 Share Posted July 3, 2008 As long as its a good quality semi or fully synthetic, check the spec for API it should be fine, unless your running a fully built high spec motor, theres a lot of oil snobbery on here;) Quote Link to comment Share on other sites More sharing options...
Thorin Posted July 3, 2008 Share Posted July 3, 2008 As long as its a good quality semi or fully synthetic, check the spec for API it should be fine, unless your running a fully built high spec motor, theres a lot of oil snobbery on here;) I wouldn't use semi-synthetic at all. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted July 3, 2008 Share Posted July 3, 2008 theres a lot of oil snobbery on here;) There seems to be a fair bit of oil stupidity too FFS there is nothing snobbish about wanting the best you can get for a none standard car. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 3, 2008 Share Posted July 3, 2008 Oh dear here we go:rolleyes: there is nothing wrong with semi synthetic, i have run a well modded SR20DET motor on it with no problems at all, and there is nothing wrong with using the best you can find, its just pointless unless you have a highly stressed engine as i said, running over specked oil on the Supra engine is just a waste of money, as its not that special, mechanically speaking. Quote Link to comment Share on other sites More sharing options...
Thorin Posted July 3, 2008 Share Posted July 3, 2008 Oh dear here we go:rolleyes: there is nothing wrong with semi synthetic There's nothing wrong with it no, but personally for the money I don't see why you wouldn't go for a decent fully syn. It is a performance car after all not a family hatchback. Quote Link to comment Share on other sites More sharing options...
supra FTW Posted July 3, 2008 Author Share Posted July 3, 2008 ok i have just finnished the oil chaing with silkoline:innocent: and that stuffs not cheap lol thanks for pointing me in the right direction. p.s if thay put the adertive in the oil thay would ownly get to sell you the oil but if sold separatly thay would make two sales ££££ many thanks Matt Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 3, 2008 Share Posted July 3, 2008 [secret ring decoder on] ok i have just finnished the oil chaing with silkoline:innocent: and that stuffs not cheap lol thanks for pointing me in the right direction. p.s if thay put the adertive in the oil thay would ownly get to sell you the oil but if sold separatly thay would make two sales ££££ many thanks Matt [/ring decoder off] So the additive is being sold by a recognized oil company such as Shell, Silkolene...etc? Quote Link to comment Share on other sites More sharing options...
supra FTW Posted July 3, 2008 Author Share Posted July 3, 2008 p.p.s my car is compleatly standard so shouldnt need mega race oil should it? just checking for next time. Quote Link to comment Share on other sites More sharing options...
supra FTW Posted July 3, 2008 Author Share Posted July 3, 2008 [secret ring decoder on] [/ring decoder off] So the additive is being sold by a recognized oil company such as Shell, Silkolene...etc? the adertive is a lucas adertive, well its gone now so no need to worry about it. Quote Link to comment Share on other sites More sharing options...
AndyT Posted July 3, 2008 Share Posted July 3, 2008 p.p.s my car is compleatly standard so shouldnt need mega race oil should it? just checking for next time. Look up oilmans threads here mate. Then go to Opie Oils website for the complete breakdown of what you need throughout the car. He, oilman, gives us discount too. Quote Link to comment Share on other sites More sharing options...
