Racelogic Traction Control without ABS?
weinelm
I've been thinking for a while about installing a RLTC system, the only problem is I've got a NA without ABS.... (didn't think of that when I bought it...) I'm sure it's possible to install the system, but is it really sensible? I reckon I've got a few options:-
1) You can get wheelspeed sensors from Racelogic, but then you have to find somewhere to mount them, plus I need to have some kind of brackets made up. http://www.racelogic.co.uk/traction/wss.htm
2) I could fit my car with the toyota ABS sensors, but it turns out it's not that straight forward! I always thought that ABS would be a sort of "plug in" option at the factory. But... the hubs and carriers are different on non ABS cars (why did they do that!), so I think you need:-
- ABS Front hubs/carriers
- Rear hubs/carriers
- Rear drive shafts, as these have the tooth wheels on.
- ABS sensors and moutings
And all that doesn't even give you a working ABS system, for that you'd still need: ABS pump, ABS controller, wiring loom with ABS connections, acceleration sensor, all new brake pipes, mountings and connections...
3). Sell my car and buy one with ABS! But I don't really want to do that as I've spent so much time and money on my current one! ... Unless anyone has a really nice Black SZ/SZ-R manual WITH ABS taking up too much room?
I favour the second option, but what's it likely to cost? Anyone got any other ideas??
1) Easiest and quickest, just find a company that can install the sensors and the RLTC, I would never of got mine working, so was glad I took it to Matt H to get the install done, but I had ABS in the first place.
2) That is a bad idea, The amount of cost and time to get that fitted would be horrendous. DO NOT ATTEMPT THIS.
3) Not a bad idea, depends on, as you say, how much you have already spent on your current car.
Option 1 seems the best idea to me. IMHO.
I can't count the number of times I've ended up arse out in my NA. Especially if driving hard.
There's hundreds of roundabouts in Telford, and crappy cars leaking oil.
Yup me too. Good fun, but not on a Monday morning on the way to work.... :upside:
I thought option 1 one might be the easiest, but I got a quote from a scappy for £60 for each front hub. I don't know what rears with drive shafts would cost though. Plus I think (hope) my bearings are ok at the mo, I don't really want to mess!
Been doing a bit more digging.
1) Wheelspeed sensors £250
2) Bits from a scrappy:-
2x Front hub and carrier = £120
2x Rear hubs and carrier = £100
2x Rear drive shafts = £100
None of this includes fitting. But I generally try and do stuff myself. So option one probably is cheaper, I'm just not sure there is anywhere practical to mount the sensors (but haven't looked closely). Option 2, is not a whole lot of dosh more, and would be a neater solution - but there is the potential for putting dodgy bearings on the car :eek: !
How difficult is it to swap these bits? What are the knuckle joints like to get off and on? (I confess to knowing very little about this, some parts may not be reusable :confused: )
Pretty much decided I'm not going to sell the car, so probably will have to speak a racelogic installer soon!
beg to differ.....
If you pratt about even the NA auto.. you get it to step out....
Have to agree here it 's not the amount of power per say or even knowing you car very well. It's the the fact that the surface conditions can change and will at some point catch us all out. I have felt the brunt of this in many different cars and have always driven with the TC OFF. Now that it has cost me some expensive metal I think that the cost of a little secutiry far outweights the cost of the car .And i shall be leaving the TC on futher cars in crap weather and still have as much fun as in the dry .....not that RTLC is invincible because it will not stop overlandish behavior but it help to get a little more out of a car if you are not a top end driver like me :tongue:
2x Rear hub and carrier = £100
I'm still weighing up my options :rolleyes: Anyone know how difficult it is to swap these parts?
  • 4 years later...
  • 1 month later...
