Baz786 Posted June 20, 2006 Share Posted June 20, 2006 My brother scrambled the setting on my Apexi AVCR [ANGRY][/ANGRY] and now my car runs at .9 bar even though the limit is set to 1.2 bar. The DTY figure needs setting, I dont know what this should be set at. It was previously running at 1.2 bar, Can someone let me know what the DTY figure should be please?? Quote Link to comment Share on other sites More sharing options...
bondango Posted June 20, 2006 Share Posted June 20, 2006 My brother scrambled the setting on my Apexi AVCR [ANGRY][/ANGRY] and now my car runs at .9 bar even though the limit is set to 1.2 bar. The DTY figure needs setting, I dont know what this should be set at. It was previously running at 1.2 bar, Can someone let me know what the DTY figure should be please?? Keep increasing the Duty +1 until it holds 1.2 bar Quote Link to comment Share on other sites More sharing options...
imi Posted June 20, 2006 Share Posted June 20, 2006 yup...agree with bon Quote Link to comment Share on other sites More sharing options...
supRo Posted June 20, 2006 Share Posted June 20, 2006 I get about 0.9/1 bar without BC on BPU car. Try 50% Duty cycle Quote Link to comment Share on other sites More sharing options...
Baz786 Posted June 20, 2006 Author Share Posted June 20, 2006 Thanks guys. Ill give it a try Quote Link to comment Share on other sites More sharing options...
bondango Posted June 20, 2006 Share Posted June 20, 2006 Baz what has your Brother changed the Duty setting too? As a pointer, the Duty Setting on you high boost will always be higher than that of your low boost setting. Have a look what the duty of your low boost setting is, use this + about 15% for your high setting to get you started off. Then keep adding or subtracting if need until you get it right. No 2 cars have the same Duty Settings as each car is slightly different. Quote Link to comment Share on other sites More sharing options...
