MichaelG Posted December 5, 2004 Share Posted December 5, 2004 Hi folks Can someone please give me a definite answer as to what type of bulbs are in my 1993 MKIV J-Spec N/A please ? I am planning on changing all the bulbs to LED Type, but need to know the bulb types to compare. I changed the bulbs for some similar items on my 1993 TT J-Spec a few years ago, and remember vaguely a problem that a standard H4 or H7 bulb whatever it is, didnt fit properly in the socket on a J-Spec as it was slightly different. So...............for dipped headlight / sidelight and main beam, what are all the bulb types that i need, H1/H4/H7 ?!?!? And will standard UK Spec bulbs from any bulb retailer fit or do i need different ones ? I am assuming the sidelight bulbs are just simple T10 Small wedge type bulbs ? Thanks in advance Michael Quote Link to comment Share on other sites More sharing options...
JayDub Posted December 5, 2004 Share Posted December 5, 2004 The driving/fog lamps are H3? I think (the one with the tail on it - fairly sure it's H3). Side lamps are T10 & I haven't got around to the headlamps yet! I changed my side lights to blue LED - looks great, but overshadowed by fog lamps. If anyone knows where you can get LED H3's (I still think!) I'd be grateful......... Quote Link to comment Share on other sites More sharing options...
Pete Posted December 5, 2004 Share Posted December 5, 2004 Annoyingly I think they're still called the same thing? All the ones I've ever bought for my J Spec have been too fat and needed dremelling round the edge to fit. Very annoying (and smelly) Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 5, 2004 Share Posted December 5, 2004 I've just changed em all so I know this off hand. For J-Spec lights you want: Dip 9005 (HB3) Main 9005 (HB3) Fog H3 Side W5W? The UK's use a 9006 (HB4) for the dips but these will not fit in the J-Spec bulb holders as the base is too big. The 9005's fit in the j-spec dip location fine but you first need to trim/file off the two little plastic locator tabs in the plug on the bulb (took me 2 minutes). No idea on LED's though. Quote Link to comment Share on other sites More sharing options...
Pete Posted December 5, 2004 Share Posted December 5, 2004 Hoorah! No more dremmel! Quote Link to comment Share on other sites More sharing options...
Jake Posted December 5, 2004 Share Posted December 5, 2004 I think you'll find that the only bulbs that are a direct replacement (with no trimming etc) are 9006J and 9005J. You can use 9005 and 9006 bulbs but they need some minor modification. Quote Link to comment Share on other sites More sharing options...
FaithStalker Posted December 5, 2004 Share Posted December 5, 2004 be careful with your rear lights and swapping for LED's my 93 version have the bulbe pointing directly upwards, (i.e. vertically mounted) so when you buy LED's they are also pointing up and they just light up half the light.... i think it changed on faelift models. Quote Link to comment Share on other sites More sharing options...
MichaelG Posted December 5, 2004 Author Share Posted December 5, 2004 Brilliant thanks a lot folks, so am i safer going with the 9005J and 9006J to save any fiddly trimming etc ? Cheers Michael Quote Link to comment Share on other sites More sharing options...
Jake Posted December 5, 2004 Share Posted December 5, 2004 Yeah but good luck trying to find some! The regular 9005 bulbs are much easier to find and it only takes a minute to trim them to fit. Quote Link to comment Share on other sites More sharing options...
MichaelG Posted December 5, 2004 Author Share Posted December 5, 2004 LOL Ok so............majority says 9005's trimmed to fit into the Main Beam and Dip beam sockets, and Two H3 Bulbs, one for each fog socket yeah ? Just want to make sure before i spend a wedge lol Michael Quote Link to comment Share on other sites More sharing options...
FaithStalker Posted December 6, 2004 Share Posted December 6, 2004 this may help http://mkiv.com/tmp/bulb_guide.jpg http://www.3dzled.com/vehicle.html and this place (go back to the menu from the link...) http://www.trendcruiser.com/detail.asp?product_id=POLM10 Quote Link to comment Share on other sites More sharing options...
mawby Posted December 6, 2004 Share Posted December 6, 2004 If you don't mind spending a little money get the H217 from PIAA. They are much brighter than stock, and have the great advantage that they fit both the main beam and dipped headlight fittings. Quote Link to comment Share on other sites More sharing options...
tbourner Posted December 6, 2004 Share Posted December 6, 2004 Cool does that mean that the H290E (9005/6 HB 3/4 55=100W) will fit as well? Quote Link to comment Share on other sites More sharing options...
mawby Posted December 6, 2004 Share Posted December 6, 2004 Originally posted by tbourner Cool does that mean that the H290E (9005/6 HB 3/4 55=100W) will fit as well? I don't know, I haven't tried! I think the key bit is the fact these bulbs are designed for both 9005 & 9006, so yes they should fit. Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted December 6, 2004 Share Posted December 6, 2004 Mr Gellie? You got a supra again? Me Too!! Quote Link to comment Share on other sites More sharing options...
MichaelG Posted December 6, 2004 Author Share Posted December 6, 2004 LOL alright mate Yeah a 93 J-Spec N/A Sold the Skyline / Evo / Escort Cossie lol all of them and went sensible and reliable. Still like the looks of the Supe though. Red, Veilside Kit and 19"s What u got ? MG Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted December 6, 2004 Share Posted December 6, 2004 '95 White RZ 6sp Blitz front, 18" volks No doubt see you round Which aberdeen local forum you on these days? Quote Link to comment Share on other sites More sharing options...
MichaelG Posted December 6, 2004 Author Share Posted December 6, 2004 Dont use any of them at all mate, not done in ages.........too many saxos !! Quote Link to comment Share on other sites More sharing options...
lightwave Posted December 7, 2004 Share Posted December 7, 2004 Originally posted by FaithStalker be careful with your rear lights and swapping for LED's my 93 version have the bulbe pointing directly upwards, (i.e. vertically mounted) so when you buy LED's they are also pointing up and they just light up half the light.... i think it changed on faelift models. You can get right-angle LED bulbs for the rear now though. The problem is (at least with the J-spec) that the bulbs has offset bayonet fittings, not opposite ones. The only LED bulbs I can find have opposite fittings. Apparently it does no harm to just remove one of the bayonet pins so just one fits into the offset bulb holder. It should still stay where it is I've been told. Anyone got any experience of this? Quote Link to comment Share on other sites More sharing options...
