Glosphil Posted December 13, 2007 Share Posted December 13, 2007 What is the expected benefit from installing cams into a BPU car? and will the standard ECU cope with it? Recommendations for a fast road/odd track day car. Thanks Link to comment Share on other sites More sharing options...
Wez Posted December 13, 2007 Share Posted December 13, 2007 People have used cams without changing fueling and ignition but in my opinion to get the most from them you should adjust both. EDIT Benefit: better breathing up top, more air and more fuel equals more power Link to comment Share on other sites More sharing options...
Alex Posted December 13, 2007 Share Posted December 13, 2007 256in / 264ex for fast road on stock based turbo's.... Link to comment Share on other sites More sharing options...
Nic Posted December 13, 2007 Share Posted December 13, 2007 I fitted in256/ex264 cams when BPU, it gave noticeable improvements in mid to top end power. I had the emanage fitted at the same time which as Wes says, helps get the best out of the cam swap. Link to comment Share on other sites More sharing options...
Glosphil Posted December 13, 2007 Author Share Posted December 13, 2007 And would these still be ok for when I go single? Link to comment Share on other sites More sharing options...
Alex Posted December 13, 2007 Share Posted December 13, 2007 yes Link to comment Share on other sites More sharing options...
Wez Posted December 13, 2007 Share Posted December 13, 2007 Stock Cams PHR Stage 1 (60-1) Same car with HKS 264/264 - lower boost, boost control not finished Link to comment Share on other sites More sharing options...
Nic Posted December 13, 2007 Share Posted December 13, 2007 And would these still be ok for when I go single? Yes they'll be ideal for a T61, GT35R, etc. sized turbo Link to comment Share on other sites More sharing options...
Chris and Alana Posted December 13, 2007 Share Posted December 13, 2007 Would installing larger cam's still retain the gap between pistons and valves (keeping it a non-interference engine)? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 13, 2007 Share Posted December 13, 2007 I think until you go past 272 you are fine, still non interference. Link to comment Share on other sites More sharing options...
Alex Posted December 13, 2007 Share Posted December 13, 2007 You have 10mm of clearance in total on stock pistons. The 256/264's use about 9mm's Link to comment Share on other sites More sharing options...
tucky40 Posted December 21, 2007 Share Posted December 21, 2007 I noticed Whifbitz are advetising the Brian Crower Cams, wondering if anyone has considered these?? They seem a fair bit cheaper than the HKS ones? are they just as good? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 21, 2007 Share Posted December 21, 2007 AFAIK only the MK III cams are available so far. Link to comment Share on other sites More sharing options...
D3xt3r Posted December 22, 2007 Share Posted December 22, 2007 Check out Piper Cams they have cams for the 2JZ too and they are really great. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 22, 2007 Share Posted December 22, 2007 Check out Piper Cams they have cams for the 2JZ too and they are really great. No cams for the Supra engine listed on their site. Link to comment Share on other sites More sharing options...
SteveL Posted December 22, 2007 Share Posted December 22, 2007 I noticed Whifbitz are advetising the Brian Crower Cams, wondering if anyone has considered these?? They seem a fair bit cheaper than the HKS ones? are they just as good? ... I was going to use these in mine, but they haven't finished manufacturing them yet. They seem to be about 6 months behind in producing them - so I went for HKS ones. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted December 22, 2007 Share Posted December 22, 2007 Guys JUN are worth a look in my opinion....very good gear and fairly sure cosworth have a very big influence in the design Link to comment Share on other sites More sharing options...
RobSheffield Posted December 22, 2007 Share Posted December 22, 2007 Guys JUN are worth a look in my opinion....very good gear and fairly sure cosworth have a very big influence in the design Ill be using JUN 264s sourced from Nic Link to comment Share on other sites More sharing options...
tucky40 Posted December 22, 2007 Share Posted December 22, 2007 how do jun prices compare to hks? Link to comment Share on other sites More sharing options...
Nic Posted December 23, 2007 Share Posted December 23, 2007 how do jun prices compare to hks? Similar price to the HKS cams Link to comment Share on other sites More sharing options...
