fri3ndly Posted December 13, 2007 Share Posted December 13, 2007 Well after I finally managed to get the door open (after the amount of frost that had stuck it shut), I turned the ignition and just got a click noise.... After several attempts to start it I decided to go and get a hair dryer and point it in my engine to warm it up a bit. Turns out that pointing it at the starter motor did the trick and it finally worked after 10 mins heating.... Now my question.....is that normal!? Link to comment Share on other sites More sharing options...
dannysupratt Posted December 13, 2007 Share Posted December 13, 2007 Well after I finally managed to get the door open (after the amount of frost that had stuck it shut), I turned the ignition and just got a click noise.... After several attempts to start it I decided to go and get a hair dryer and point it in my engine to warm it up a bit. Turns out that pointing it at the starter motor did the trick and it finally worked after 10 mins heating.... Now my question.....is that normal!? I have had this happen a few times not on the supra though, The best way i find is to put the car in second with your foot ready on the clutch and get someone to rock the car forwards and backwards while you turn the key. Its always worked for me straight away its just the starter motor playing up and will probably never happen again, the hair dryer thing might of just been luck but hey atleast it started:) Link to comment Share on other sites More sharing options...
keancy Posted December 13, 2007 Share Posted December 13, 2007 I have had this happen a few times not on the supra though, The best way i find is to put the car in second with your foot ready on the clutch and get someone to rock the car forwards and backwards while you turn the key. Its always worked for me straight away its just the starter motor playing up and will probably never happen again, the hair dryer thing might of just been luck but hey atleast it started:) Not an option with an auto tho. Link to comment Share on other sites More sharing options...
fri3ndly Posted December 13, 2007 Author Share Posted December 13, 2007 Yeh, only problem with an auto ;-) Well I guess it must have just been so cold it froze the motor or something... Link to comment Share on other sites More sharing options...
R Black Posted December 13, 2007 Share Posted December 13, 2007 I thought starter motors did this when their bushings wear out, so they wont turn if they stop at a worn part, so that in rocking the car in gear this moves the starter to an unworn part? Heating it probably just expanded everything making it contact again. Link to comment Share on other sites More sharing options...
Rob Posted December 13, 2007 Share Posted December 13, 2007 Aye, single click generally means starter motor contacts need replacing. There is a comprehensive guide on here. Link to comment Share on other sites More sharing options...
stevie_b Posted December 13, 2007 Share Posted December 13, 2007 Does this sound familiar? : http://www.mkivsupra.net/vbb/showthread.php?t=92698 or http://www.mkivsupra.net/vbb/showthread.php?t=78173 I reckon it could be the starter motor contacts. You can refurb them without buying a whole new motor. I think there's a howto in the FAQ section. Link to comment Share on other sites More sharing options...
fri3ndly Posted December 13, 2007 Author Share Posted December 13, 2007 Great, thanks for the help guys Link to comment Share on other sites More sharing options...
Darragh Posted December 13, 2007 Share Posted December 13, 2007 my starter motor is going in for its third overhaul they realy are crap i think its a common fault with the supras Link to comment Share on other sites More sharing options...
miko_supra Posted December 13, 2007 Share Posted December 13, 2007 when was the last time your battery was replaced? might be worth checking that as they dont like the cold weather Link to comment Share on other sites More sharing options...
Guest dangerousandy Posted December 17, 2007 Share Posted December 17, 2007 I don't believe it - My supra has started doing this too!!! GRRR! but I have noticed that my battery terminals are quite loose on the new (varta) battery I have fitted even though the nuts are as tight as they can go. Sometimes she starts fine, other times I can be there for 15mins trying to get the damm thing to go. I will be seeing to the battery terminals to see if that makes a difference. Not happy! Link to comment Share on other sites More sharing options...
