VenomX Posted December 12, 2007 Share Posted December 12, 2007 My wheels are 255/35/18" and every time there's irregularity on the road or tight cornering the wheels touch the rear arches producing a nothing healthy scraching noise. http://img525.imageshack.us/img525/705/wheels001lc0.th.jpghttp://img143.imageshack.us/img143/4144/wheels002ho4.th.jpghttp://img99.imageshack.us/img99/597/wheels003qu5.th.jpg Every piece of information on how to best solve this matter is much appreciated. Thanks in advance. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted December 12, 2007 Share Posted December 12, 2007 for that width your wheels are obviously the wrong off set . I run 275/30/19's on my rears with no problems . the only thing i can suggest is get some new wheels if ya want a cheap rough fix try those bump stops that you wrap in your spring coil but beware you loose ya suspension so it will become very hard Link to comment Share on other sites More sharing options...
bignum Posted December 12, 2007 Share Posted December 12, 2007 Try and raise the car or get some wheels with correct offsets. Link to comment Share on other sites More sharing options...
CarlT67 Posted December 12, 2007 Share Posted December 12, 2007 You could roll the arches, that would fold that lip on the underside flush, dont know if that would be enough to clear though... What ever you do, do it quick before road salt and rust get started on it.... Link to comment Share on other sites More sharing options...
VenomX Posted December 12, 2007 Author Share Posted December 12, 2007 for that width your wheels are obviously the wrong off set . I run 275/30/19's on my rears with no problems . the only thing i can suggest is get some new wheels if ya want a cheap rough fix try those bump stops that you wrap in your spring coil but beware you loose ya suspension so it will become very hard Very hard but safe, right? Link to comment Share on other sites More sharing options...
R Black Posted December 12, 2007 Share Posted December 12, 2007 Did you buy the car like this? if so has it got spacers on? if so take them off Link to comment Share on other sites More sharing options...
VenomX Posted December 12, 2007 Author Share Posted December 12, 2007 Did you buy the car like this? if so has it got spacers on? if so take them off I did bought it like this, obviously didn't know it was like this. No there are no spacers. Link to comment Share on other sites More sharing options...
Carl_S Posted December 13, 2007 Share Posted December 13, 2007 Sorry to hear about your prob mate, it's a bugger. This is what I would consider, in no particular order: 1) Chocks in suspension to raise car. 2) modified shocks and springs to raise car. 3) Roll or cut arches. 4) Get overfenders properly welded on. 5) Buy narrower wheels / wheels with correct offset. 6) Get adjustable suspension with the stiffest springs. Link to comment Share on other sites More sharing options...
Suprash Posted December 13, 2007 Share Posted December 13, 2007 I would get them rolled first if you dont want to bin the wheels, its the cheapest option, £45 per side, it will fold that lip right up and flat...... Link to comment Share on other sites More sharing options...
Carl_S Posted December 13, 2007 Share Posted December 13, 2007 yeah rolling is cost effective, and maintains the strength of the bodywork, unlike cutting. But check it out professionally to make sure its going to clear those arches after they are rolled, becuase its looks like to me that the tyres actually protrude from the bodywork (just like mine although less) Link to comment Share on other sites More sharing options...
VenomX Posted December 13, 2007 Author Share Posted December 13, 2007 thanks guys you're supra Link to comment Share on other sites More sharing options...
Nic Posted December 13, 2007 Share Posted December 13, 2007 Your wheels look illegal, wheels are not suppose to protrude past the wheel arch like that. They are obviously the completely wrong offset, which will be badly compromising the handling. I'd fit a new set of wheels personally and flog those on ebay. Link to comment Share on other sites More sharing options...
spidermonkey Posted December 13, 2007 Share Posted December 13, 2007 Your wheels look illegal, wheels are not suppose to protrude past the wheel arch like that. They are obviously the completely wrong offset, which will be badly compromising the handling. I'd fit a new set of wheels personally and flog those on ebay. I agree, Deffinately get some different wheels mate with the correct offset, you should be able to get some quite cheap off e bay Link to comment Share on other sites More sharing options...
Thorin Posted December 13, 2007 Share Posted December 13, 2007 Your wheels look illegal, wheels are not suppose to protrude past the wheel arch like that. They are obviously the completely wrong offset, which will be badly compromising the handling. I'd fit a new set of wheels personally and flog those on ebay. Must be a lot of stress on wheel bearings with that offset. Link to comment Share on other sites More sharing options...
Supra-Brett Posted December 13, 2007 Share Posted December 13, 2007 Your wheels look illegal, wheels are not suppose to protrude past the wheel arch like that. They are obviously the completely wrong offset, which will be badly compromising the handling. I'd fit a new set of wheels personally and flog those on ebay. Yep i agree, the wrong offset, and illegal as they protude beyond the arches I used to run 265/30/19s without rolled arches no problems (i think widest you can go without rolling is 275. Ive now had my arches rolled and gone up to 295/35/19 with no problems. Beware of rolling though. Although it may only cost ~£45 to 80 a corner, if the paint cracks whist its being done, you will be shelling out a lot more on respray costs in the end. I think its better to sell the alloys and buy new ones. Link to comment Share on other sites More sharing options...
VenomX Posted December 13, 2007 Author Share Posted December 13, 2007 My wife is going to kill me now "Dear I need to spend another £800 on a new set of rims". :d:d I think she'll kick me and the car out. hahaha Cheers guys, very helpful indeed. By the way what's the recommended size for the Supra? Link to comment Share on other sites More sharing options...
