Carl_S Posted December 12, 2007 Share Posted December 12, 2007 I'm about to take the hoses off, but not unless there's coolant in there. I have no idea becuase I'm a newb. Carl Quote Link to comment Share on other sites More sharing options...
keron Posted December 12, 2007 Share Posted December 12, 2007 i hope not no its air... Quote Link to comment Share on other sites More sharing options...
Carl_S Posted December 12, 2007 Author Share Posted December 12, 2007 great off it comes then... lol Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted December 12, 2007 Share Posted December 12, 2007 I'm about to take the hoses off, but not unless there's coolant in there. I have no idea becuase I'm a newb. Carl Are you sure you're refering to the FMIC? Has it just got two large (2.5"ish diam) pipes coming off it? If so, it's dry (maybe a single drip of oil, or just dampness). Too slow!! Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted December 12, 2007 Share Posted December 12, 2007 Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted December 12, 2007 Share Posted December 12, 2007 You seem confused Nic? Quote Link to comment Share on other sites More sharing options...
Carl_S Posted December 12, 2007 Author Share Posted December 12, 2007 it's obviously been idiot proofed. Cant get access to the jubilee clip to take off the hose. And yes, big pipes here 2.5". Guess I will have to give up and screw it all back on, it was fun though. Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted December 12, 2007 Share Posted December 12, 2007 it's obviously been idiot proofed. Cant get access to the jubilee clip to take off the hose. And yes, big pipes here 2.5". Guess I will have to give up and screw it all back on, it was fun though. Why were you taking it off mate? Quote Link to comment Share on other sites More sharing options...
Carl_S Posted December 12, 2007 Author Share Posted December 12, 2007 Give me increased ground clearance at the front, until next year when I get my car raised. Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted December 12, 2007 Share Posted December 12, 2007 Give me increased ground clearance at the front, until next year when I get my car raised. Just a precaution, or have you whacked it already? How much clearance have you got at the mo? Quote Link to comment Share on other sites More sharing options...
Carl_S Posted December 12, 2007 Author Share Posted December 12, 2007 a tiny scrape on an unseen area. i got 4" clearance at the moment Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted December 12, 2007 Share Posted December 12, 2007 You seem confused Nic? More worried than confused Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 12, 2007 Share Posted December 12, 2007 Am I reading this right, you were going to remove the FMIC because it catches the ground, what were you going to put in its place the old SMIC ?? Quote Link to comment Share on other sites More sharing options...
CJ Posted December 12, 2007 Share Posted December 12, 2007 Am I reading this right, you were going to remove the FMIC because it catches the ground, what were you going to put in its place the old SMIC ?? I was thinking that too. Quote Link to comment Share on other sites More sharing options...
michael Posted December 12, 2007 Share Posted December 12, 2007 Efmic? Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted December 12, 2007 Share Posted December 12, 2007 Efmic? Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted December 12, 2007 Share Posted December 12, 2007 Efmic? don't go giving people ideas Quote Link to comment Share on other sites More sharing options...
Matt H Posted December 12, 2007 Share Posted December 12, 2007 Am I reading this right, you were going to remove the FMIC because it catches the ground, what were you going to put in its place the old SMIC ?? I really really hope he was just intending to take it off full stop I can see it "umm, this part of my engine is a bit low to the ground, ahh i'll just get rid of it"!!! Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 12, 2007 Share Posted December 12, 2007 Could have been worse, he could have filled it up with coolant Quote Link to comment Share on other sites More sharing options...
turbonut Posted December 12, 2007 Share Posted December 12, 2007 .....and the sump could be in the way... Just kidding!! if you dont ask..... Lxx Quote Link to comment Share on other sites More sharing options...
MRX Posted December 12, 2007 Share Posted December 12, 2007 In my ignorance and only owning an N/A I had incorrectly assumed that that the intercooler system worked much like the standard radiator system and was water cooling the turbo. If the Intercooler is just an air to air heat exchanger how is air forced round the system? is there a diagram of how this works anywhere? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 12, 2007 Share Posted December 12, 2007 The intake air passes in through the airfilter, from here it travels into the turbo compressor (the alloy part) here the intake air is compressed (to a "boosted level") and pumped into the intercooler. When the air is compressed it gets hot, (not from the hot turbo) but due to when all air is compressed it gets hot. The intercooler (air to air) on the WRX uses cold air from the bonnet scoop passing through the fins to cool the hot inlet air that is passing through the other (inside part) of the intercooler. The inlet air gives off heat to the cooling air. The cold air allows a more dense inlet charge to pass through the throttle body butterfly, (which is connected to the accelerator pedal) then into the inlet manifold, here fuel is squirted in at high pressure from the injectors, where it mixes and passes into the combustion chamber (engine). It goes bang, and heats up, (expands) gives off energy and passes out through the exhaust manifold and into the turbo. As the air expands it drives the turbine wheel (connected to the compressor side wheel via a shaft) this creates the boost. This exhaust gas then passes down and out the exhaust! The colder the air entering the engine the more HP as its a denser charge with more oxygen and fuel. BUT do not get this mixed up with air temps at the airfilter, as this is only marginal in changes effecting the BIG increases in temps when the air is compressed in the turbo. It is only possible to change the air filter inlet temps by a couple of degrees and this is marginal on effect of performance. The temperature before the intercooler is very high and thus easily reduced as the difference between inside and outside temps of the intercooler are large. (The larger the difference the easier to effect change) NOTE. Air to water intercoolers (like Liberty / Legacy) are better than air to air, but more costly to make. Obviously water can soak up more heat and transfer it than air! Quote Link to comment Share on other sites More sharing options...
Carl_S Posted December 12, 2007 Author Share Posted December 12, 2007 lol. I can see the confusion. I suppose this thread should read in conjunction with the veilside splitter thread. Anyway, its my bad for misleading you. Its not the FMIC that im taking off to improve clearance its the front splitter that I'm taking off - and just managed it. I thought I needed to take off an FMIC hose to get access to the splitter bolts, but I managed without. It looks much better without the splitter - even more crazy and agressive, so right up my street. So Happy that I did it. I thought about repairing and eventually re-fitting the splitter, now I'm not so sure. I might just bin it. Quote Link to comment Share on other sites More sharing options...
Carl_S Posted December 12, 2007 Author Share Posted December 12, 2007 In my ignorance and only owning an N/A I had incorrectly assumed that that the intercooler system worked much like the standard radiator system and was water cooling the turbo. If the Intercooler is just an air to air heat exchanger how is air forced round the system? is there a diagram of how this works anywhere? glad I also didn't know. nice not to be the only newb. Quote Link to comment Share on other sites More sharing options...
Carl_S Posted December 12, 2007 Author Share Posted December 12, 2007 .....and the sump could be in the way... Just kidding!! if you dont ask..... Lxx now that you mention it L, the sump is in the way and has to go!.. now!! Quote Link to comment Share on other sites More sharing options...
