Which Clutch?
Tricky-Ricky
Anyone have any relevant prices? i have suspected mine of slipping a little in peak torque areas, but today i went out to try and get my injectors a little more dialed in and the dam thing was definitely showing signs of slippage:(
I might as well try and get another flywheel as mine clonks a fair bit:( anyone have one cheap! i have a wanted add up,
Typical thought i just get myself a bargain inlet cam and am looking for the exhaust and this has to rear its ugly head, so i may not be able to afford the other cam:( Bugger!
I can get the following for similar prices, centreforce (twin plate design?) RPS max street and a Clutchmaster (US company) looks like an ACT which is a six puck design, all seem to be up to the job, what do you think? i am curious about the centerforce twin plate design, anyone have this?
Also if being used with a std flywheel would having a sprung friction plate make any difference?
Can't find any links or info on Southbend clutches??
http://www.mkiv.com/techarticles/clutch/index.html
Racing-Clutch.com | Racing Clutch | South Bend Lathe | South Bend ...
South Bend Clutches · SBC for Diesel Pickups Free Shipping on All Clutches · xtremediesel.com/ · Shop Southbend Equipment ...
http://www.racing-clutch.com/south-bend-clutch.htm?tkn=vHelzD6KX_IKEwj544TA_tiNAhUnHWAKHZgyJh8YASADML3TrBA4DQ
Any help?
