Fitting kitchen cabinet lighting, any Electricians here?
osso
I have bought some Low voltage kitchen lighting, for upper cabinet and under cabinet lighting controlled by two low voltage dimmer switches.
Normally I would extend the existing lighting ring main circuit, but here's the problem, I live on a one floor flat, so I am unable to rip the neighbours floorboards up! :D
The easiest option would be to take a spur from the main ring main and create a small spurred lighting circuit using 2.5mm twin and earth cable. see attached image...
I am hoping someone on here could tell me if this be a sensible safe approach?
I've got several meters of old 2.5mm twin and earth bought before the regs took place :D I am pretty much on the ball when it comes to wiring, but never taken a spur off a ring main to make a switched circuit. So trying to find out whether this is the done thing to do under the circumstances living on a singe floor flat.
You put in a low rated fuse straight off the spur. Its no biggy really if you consider the fact that all of europe's electric is wired up just like this ie no light circuits separate from ring mains and bugger all fuses.
In fact if you are really worried put the fused spur into a socket and put a 3 pin plug onto the light flex.
I was considering putting a 3am fuse off the spur as suggested by the instructions it came with. I was also considering to even convert the suggested radial spurred lighting curcuit into a ring main, and putting a fused FCD before each transformer. but thought that was OTT
