Plumbimg/heating help needed
Bill Prawn
Why does this only happen on holidays?
Hot water cylinder is discharging water from the overflow.
Don't know why, but if we turn off the water heater it stops.
Any help will be greatly received :)
It's a Vaillant Vantage if that helps :blink:
I'd say that there's definitely some sort of problem with it. :blink:
what type of sytem do you have a combi or conventional? The hot water over flow out side maybe just a sign that the tempreature is not regulating quite as it should.
It's the old, as the water gets hotter it exspands type of thing, so it's i dont think any harm will come of it.
Or it might also be a sign, (if you have a conventional system with a small exspansion tank in the loft) that the ball cock valve is not quite as good as it used to be and migh neeed repacing.
this sounds a bit like a problem i had, when the heating came on the pressure suddenly shot up and vented itself all over my decking, when it was cold again there was zero pressure and it was the expantion cylinder, re-pressurised it with my bike pump and hey presto working again!!! neighbour paid over £300 to have his "replaced" and system flushed :)
It could be the pressure in the expansion tank is low or it could be the diaphragm in the expansion vessel is breached. Putting some more air in it with a footpump should tell you if that is your problem. I take it that its snotty horrible coloured water coming out? Is your heating system losing pressure?
Fresh hot water.
Heating is all ok :conf:
Could be the over pressurise valve itself. Spring in it or something weakened. Is there a book that came with the boiler or can you find some info on a website. My boiler came with an installation and engineers handbook thingumy which has a fault finding section in it.
http://www.gasconnect.co.uk/central/unvented_hot_water.html
Give them a ring they might be able to help you out with this problem
