little bit of advice on replacing gasket
miko_supra
I have a Toyota pdf here for the 2JZ-GTE which, in the section for adjusting valve clearances, when it gets to refitting the valve covers states:
Apply sealant at indicated No. 1 and 2 valve cover
sealing areas on front of cylinder head. See Fig. 8. Using NEW
gaskets, install No. 1 and 2 valve covers. Tighten bolts to
specification.
I just used Hermetite red.
Here's the pic:
