Is my FTP server working??
Chris Wilson
That's because you need to use the internal private IP address. Something known as split-DNS would be the way to do it in a proper server environment.
What you need to do is add an entry to %systemroot%\system32\drivers\etc\hosts on the client machine like this:
[ip address] (tab) ftp.chriswilson.tv
leave the square brackets out. You'll see the format of the line from the existing "127.0.0.1 localhost" entry.
I'm presuming from all this that's it's a locally hosted FTP server, which I think is correct, and you're using Port-redirection (NAT/PAT) to get external people into the machine.
Or just try logging into server name "localhost".
