skyline help from supra guys..
Guest rockabilly
Guest rockabilly
hi guys, not sure if this is my first post as i have had to register again.. i am after some help and you guys are it:)
just built myself an rb30 ozzie block with rb26 head..
now i know some of you guys use the gt35r blower so with the specs below what bhp/torque would you suspect it may create and at what boost..
also what is the boost limit on this turbo 2bar?.
i ask this as not many skylines run 3.0ltr blocks so the guys on there dont really know..cheers bernie..
specs..
3.0ltr block,,bottom end balanced.
cp forgies, spool forged rods,acl bearings.
arp crank/rod head bolts.
264/272 cams 9.7mm lift.
twin tomei fuel pumps,1000cc,s and hks reg.
gt35r on 6 boost amnifold, tial 44mm ex waste
1.06 rear housing, 4" dump.
exedy triple plate clutch,
link to rebuild..al done at home..
http://s212.photobucket.com/albums/cc220/rockabillyrb30/
