Problem with in-car DVD player
damientt
I've just fitted a DVD player to the car but there's a slight hitch. It will play DVD soundtracks but doesn't display the video.
I think this might be because I didn't connect up the parking sensor wire from the unit to the handbrake wiring harness. Arse!!
If I connect the wire a ground source will this solve the problem or do I need to do something else? :innocent: I don't want to connect it to the handbrake, partly because I never use it.
As i started a thread the other day ALL U HAVE TO DO IS EARTH IT :D, as per advice from the guys on here, take of the center console where there gear lever is, there are screws all around the place, Trim a bit of the parking sensor wire, unloosen a screw, put the wire under the screw and then tighten the screw ontop,......ur dvd player will work then.....
