crash bar, bumper and its supports
TurboBrett
hi every one:)
i have been doing loads of research, in advance of fixing the supe but there are a few questions i cant find answers too,
1)i think for now the front will go again, not spraying it but will be replacing it with either, top secret , do luck (no.2?) and i think there was one more but that style, i have read on this thread (and others)clickythat the crash bar needs to be removed on some, now from experiance i found it usefull:d and wanna keep it, so will the top secret front end deffinatly fit over it? (and any other that you have tried so i can eye them up:p)
2) i will buy a new front bumper support bar because i think it will be easyer to judge if all is straight when refitting everything, i have seen on lots of post they are 24quid but what do i actualy get see pic, (thanks to madmunky:))
and part numbers welcome:)
It's just a bit of alu box section about 4inx 2.5in that goes across the two points on your picture.
I would not recommend using that to see if your chassis is damaged! If you're in any doubt, get it checked on a jig. It should be fairly obvious if they have moved as there will be crazing on the paintwork and sheet metal welded to the legs.
Looking at your crash pics it seems like the impact was above the chassis legs, so I think you'll be okay :)
nah lol i wasnt too clear (dont think the pic helped) my alu bar is spot on not even a scratch, like you say the impact was at light hight so its the bar that the top side of the bumper where it screw/clips(what ever they was) and the bonnet meets the front that is bent i am trying to find out what its called
the lines in the pick are from what madmunky put, on its the bars above and that seem to go round the light i am interested in :) can i get new they seem to un bolt?
I have the same worry.When i fitted my do-luck i had to remove the x member for the bumper to be fitted. I was worried so i spoke to a few people who had the same bumper and one bloke said some1 on here does a modded front x member for the do-luck bumpers. But i cant remember who it was. I remember when Gammer had his crash and he showed the pics. He had a Do-luck bumper on and he hit one of the sides and the chassie leg was bent right round. Im sure he said which i agree if he had the x member on it might of stopped the car from being a right off.....
As I've said several times now, it's just a very lightweight Alu bax section that will make bugger all difference to the chassis leg strength in an accident hard enough to fold it up. It will make a small difference in VERY low speed accidents, but it's main purpose is to protect the radiator.
53205-14110 SUPPORT SUB-ASSY, RADIATOR, UPPER -> This is the panel that needs welding to the inner wings
52029-14030 REINFORCEMENT SUB-ASSY, FRONT BUMPER, UPPER -> This is the lower panel
52021-14180 REINFORCEMENT SUB-ASSY, FRONT BUMPER -> This is the 'crash bar'
I imagine the first part will be very expensive from Toyota, mnight be more cost effective checking if Jez has a straight one in stock.
nice bit of kit u have there;) and cheers for the help, i think this is all i need for sub structure will have better look sunday
fingers crossed the 'slam pannel' or rad support will bend back in to shape,its only very slightly bent and i have a set of ratchet puller things that i can get my hands on thanks to my grandads tool collection :innocent:
not sure i understand the part numbers:D i will just print of the pic and go down to toyota dealer:D
thanks again mate :)
Just so you know, the 'slam panel' can be bought from Toyota for around £85 depending on what discount you can get from them, and the bumper support bar around £25
the bumper support bar is the ally one, yeah? for £25 or is it the one in the pic i have circled?
its tuch and go at the minute wether the slam pannel will be bent back in to place or replaced its only very slightly bent will have better idea and more (smaller) pics on sunday:D
ordered the upper bumper support bar today from toyota but the price the guy quoted was £84.97 any chance the price could have gone through the roof?
i asked for 'REINFORCEMENT SUB-ASSY, FRONT BUMPER, UPPER' my exact words, hope hes ordered the right one, pick it up after wednesday wont be too happy if its not right:d
want supe on road for chrimbo with or without new bonnet just need light and this bar, the bonnet is phooked but all straight minus the big dint:(
