new speedo face
supradriver
Is this what you meant by your first post:
Im looking for a new speedo face, but im finding it hard to find one that matches up with my existing dial readings. Does anyone know where i can get an aftermarket one from that will still display the correct speeds?
it is de-limited sorry lol.
Okay, but is there a speedo convertor fitted too? Some units (such as the Thor one) combine the delimit and speedo conversion in one box, but not all do.
Is that a picture of your speedo in the first picture? If you're seeing 35 on that when you're doing 30 then it indicates that no convertor is fitted.
If you want a 180 dial with a convertor, then you will need the dial unit itself (not just the face) and a convertor.
yep sorry
If that was in relation to my last post then theres not much on offer as far as im aware that will display higher MPH in the format you have. If you are really bothered then it would be worth having a conversion done so the car reads like most other supras.
But to be honest, even though you havent explained it very well, i think you may have a speedo that shows MPH but is actually displaying KmPH (possibly)
You're correct, thats why he needs a new speedo unit (with the curcuit board on the back), the problem is, 99% of the ones out there are from Jap cars so read in kph, therefore a speedo convertor is also needed. After that he'll have the same setup the rest of the jspec owners have.
