Flamage!
hadyn
Do TT Supras pop flames from the exhaust if you have a decatted large bore exhaust system and a vent to atmosphere dump valve?? I know its a bit childish, but the flames out the back of my S14 200SX on overrun are one of my favourite features :)
I'm sure I've had flames before, full boost, full throttle, over 7k revs in first and there was a loud bang (shit my pants actually!!).
You could always just bugger up your own timing to do it (mind you isn't it because it's 100% duty cycle anyway? I dunno I'm no techie!!).
I think it's something to do with having way too much fuel going in, so when you lift off you get a load of unburnt fuel going down the exhaust and it ignites on the hot bits.
I have to confess I've been trying to get the flame effect with the E-Manage, purely just to see if it can be done of course :) I haven't got too far with it though, other things have taken priority :D
-Ian
Map for retard
What are you saying like? :D
The ignition timing retard is a trick I didn't know, I can back that right off at 6500+rpm and chuck in as much fuel as I can persuade it. So then, if I take it to the limiter and change up, it flames, otherwise it drives normally. Hahaa,it's gonna be interesting testing that!
How much would you back off the timing?
-Ian
-Ian
try backing it off to about 10 BTDC, but you'll need to experiment. By retarding it you will keep EGT's high, by adding fuel you will get flames. if the software allows crank open the IACV fully too, to add air. Basically that's what the WRC cars used to do in the old days to keep the turbo spooled, same in the BTCC when they ran the big output Cosworth Sierras. Now they used to flame a lot.... :p
  • 1 month later...
just been watching Getaway in Stockholm 2 with the black supra allegedly tuned to 450bhp - that supe seems to flame a lot, so surely all supes running vent to atmos bovs and fully decatted must flame too??
Or was this a case of hybrid turbos and aftermarket fuel management causing the flamage?
great :)
is it around £300 for both decat pipes then? and does the restrictor ring actually work stopping you from boosting past 1.2bar?
how easy are they to fit? remove cats by bolting off pipes and then refitting the decats?
great :)
Depends what you buy and where from. I had the front decat pipe made and fitted for (IIRC) £125 by a local exhaust specialist (Stealth Systems in Southampton). The car already had the second cat off when I got it.
The second decat pipe for the VVTi I bought from CJ for £70. The front decat pipe for the VVTi I get from Terry S second hand for £60
It does if it's the correct apeture for your car. This is trial and error though. Also it won't boost as high on warm days as it does when the air is cold.
Mechanically it's simple enough but undoing corroded exhaust manifold nuts is fraught with protential problems. When doing my VVTi front pipe one of the manifold studs snapped off. Restudding an exhaust manifold in situ is not my idea of fun.
