carl0s Posted December 31, 2004 Share Posted December 31, 2004 I was reading today in EVO mag that the gentleman's agreement will end shortly.... mmmm if only that meant more exciting cars were on the sunny horizon. Quote Link to comment Share on other sites More sharing options...
Clarkey Posted December 31, 2004 Share Posted December 31, 2004 For a JSpec and fitting 550cc injectors .. wouldn't you need a UK spec fuel rail and a SAFC ? Someone more techie minded will know .. like dude or Chris Wilson Quote Link to comment Share on other sites More sharing options...
tbourner Posted December 31, 2004 Share Posted December 31, 2004 I don't think Chris needs to worry about bigger injectors or single turbos yet really!!! All he needs is a single or double decat, he already has cat back exhaust and air filter, he'll need a restrictor ring (for about 1.2bar although it's not easy to get it precise first go!!), a TRL VFCC (Voltage Fuel Cut Controller), 6 NGK BCPR7ES spark plugs, preferably a Walbro 342(??) fuel pump, a nice boost gauge, and an hour on a dyno. That about cover it for BPU? Quote Link to comment Share on other sites More sharing options...
ardasaliah Posted December 31, 2004 Share Posted December 31, 2004 Hi 0.8bar on original set up. UK turbo made from steel (stronger but more lag) Jap ceramic (more brittle) Spool up quicker -weigh less Quote Link to comment Share on other sites More sharing options...
chrisda Posted December 31, 2004 Author Share Posted December 31, 2004 Thank u guys.. Ur answers have been very good. It´s not so good to spend money on things I don´t need to do with the car to set up the boost to 1.2.. By the way is there anybody that know where I can buy two twin turbos that are a little bit bigger then the original so I will get about 600hp in the car.. A place there I can buy them quite sheap? Kind regardss Chris Quote Link to comment Share on other sites More sharing options...
carl0s Posted December 31, 2004 Share Posted December 31, 2004 Thank u guys.. Ur answers have been very good. It´s not so good to spend money on things I don´t need to do with the car to set up the boost to 1.2.. By the way is there anybody that know where I can buy two twin turbos that are a little bit bigger then the original so I will get about 600hp in the car.. A place there I can buy them quite sheap? I'd love to see the plumbing for four turbos That'd put the blue spaghetti to shame! Seriously though, two larger than ct12 turbos.. well.. you could either go for very modified hybrids, but I don't think that'll get you 600hp, or you could go the twin HKS route which has been done before. Quote Link to comment Share on other sites More sharing options...
chrisda Posted January 1, 2005 Author Share Posted January 1, 2005 I'd love to see the plumbing for four turbos That'd put the blue spaghetti to shame! Seriously though, two larger than ct12 turbos.. well.. you could either go for very modified hybrids, but I don't think that'll get you 600hp, or you could go the twin HKS route which has been done before. Do u know how much the hks twin cost? But if I go down to 500 hp instead, I´m not out for going to the strip just have a nice car that is fast... Let me hear from u.. Kind regards Chris Quote Link to comment Share on other sites More sharing options...
dude Posted January 1, 2005 Share Posted January 1, 2005 Do u know how much the hks twin cost? But if I go down to 500 hp instead, I´m not out for going to the strip just have a nice car that is fast... Let me hear from u.. Kind regards Chris If you want 500hp then go the VORTEX section in traders , you need a budget Single kit with a 67 p trim turbo .You will also need some 650 drop in injectors and a means of controlling them and a fuel pump as well . Dude Quote Link to comment Share on other sites More sharing options...
chrisda Posted January 1, 2005 Author Share Posted January 1, 2005 If you want 500hp then go the VORTEX section in traders , you need a budget Single kit with a 67 p trim turbo .You will also need some 650 drop in injectors and a means of controlling them and a fuel pump as well . Dude Hi there Dude.. I want twin turbo instead of single. I think it´s loocking betten then u have more boost lower the torgue.. Do u know any small budget twin system? Chris Quote Link to comment Share on other sites More sharing options...
dude Posted January 1, 2005 Share Posted January 1, 2005 There is no cheap twin system i know of whereas the budget kit is £1800 ish a twin system is i think over £5K , IMO a huge Single is as good looking as a twin set up !! Dude Quote Link to comment Share on other sites More sharing options...
