Yet Another PC Spec
Animal
I've finally got round to getting a new PC built. I got our IT munchkin at work to spec up something decent for around the £800 mark. This is what he came up with as the 'minimum' spec he'd build. What do you reckon? It'll be used mainly for AutoCAD, recording music and playing RPGs/Star Wars games.
Lian-Li PC-60 Plus Aluminium Midi-tower case
Asus P5N32-E Plus SLi nForce Socket 775 PCI-Express DDR2 motherboard
Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB) processor
Corsair 2GB DDR2 XMS2-6400C4 TwinX RAM
Antec NeoHE 550W Modular ATX2.0 PSU
2xNoctua NF-S12 12000rpm Silent Case Fans
2xNoctua NF-R8 Silent Case Fans
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
BFG GeForce 8800GT OC 512MB GDDR3 HDTV/Dual DVI (PCI-Express) graphics card
M-Audio Delta 1010 soundcard with breakout box
Western Digital Caviar SE16 750GB SATA-II 16MB Cache hard drive
Pioneer DVR-212D 18x18 DVD+_RW Serial ATA Dual Layer ReWriter disk drive
Althou, I couldnt comment abou the sound card as I dont know about those ones. Creative man myself.
M-Audio do some top notch audiophile stuff, pricey but among the best you can get.
Edit: The 1010 has 10 inputs and 10 outputs, do you really need that many? For half the price you could get one with 4 in/out.
Yeah the M-Audio gear is for music production - capable of real time sampling with zero latency. Luckily I managed to find one on fleabay for 100 quid.
I'll be using the motherboard's on-board soundcard for the day to day stuff and the M-Audio for recording the band
Make sure you check the graphics card before install.
I have the same one and hit temps of 114degC on the GPU due to BFG sticking a stupid sticker on the center of the fan, it came loose and jammed the fan, not good :(
For some reason the memory doesnt seem to clock to well on the BFG OC cards, mine hasnt crashed since going back to stock speed 1800mhz.
id change the processor - but if your on a tight budget then leave it in
Quad Core for the win Q6600
I did think about quad core, but it would have stretched the budget a bit further than I wanted and to be honest, AutoCAD only supports up to dual core, so the benefit wouldn't be as great.
Well, it's been built and it's in the car waiting to be taken home. The lad that's built it has installed Gears of War, Quake 4 & Colin McRae Dirt on it and apparently they all run without a glitch with everything turned up full.
I can see a few late nights coming up this week...
thats a long list of ummm, stuff. do you get lemmings?
I find dual screens really useful as you can separate programs easier than on a single screen. Need to have a proper look around, but I've just seen a 20" widescreen for £149 in Comet that could be quite good. I don't think I want to spend more than £300 on a pair of monitors and they need to be 19" minimum, not too fussed about widescreen.
Do you get Lemmings tho?! :search:
My mate has this Samsung 24" on his setup and the picture really good :thumbs:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-054-SA&groupid=703&catid=17&subcat=510
Not a bad price that. I notice in the 22" range there's two samsung for around the same price, any idea what the difference is between them? Seemingly not much!
http://www.overclockers.co.uk/showproduct.php?prodid=MO-050-SA
http://www.overclockers.co.uk/showproduct.php?prodid=MO-062-SA
(edit: first one has a mustang on it, second one has a BMW, on that basis I'd go for the mustang obviously)
