Guest mossy86 Posted December 4, 2007 Share Posted December 4, 2007 1st ive a 3.0 non turbo Ok this only happened yesterday driving along 10-20mph, put the foot down and there is a major loss of power. Also when had the car parked its hunting up and down and running like a pig... But after work started up the car no problems So I done a Diagnostic putting a paper clip in TE1 & E1 & got these codes 14......24.......42 This morning had no problems So anyone any ideas?? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 4, 2007 Share Posted December 4, 2007 14 - Ignition signal - No IGF signal http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13920&d=1112558346 24 - Intake air temp sensor http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13921&d=1112558346 42 - No1 speed sensor circuit http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13923&d=1112558346 All from here Would suggest you do a ecu reset then check them again Quote Link to comment Share on other sites More sharing options...
Guest mossy86 Posted December 4, 2007 Share Posted December 4, 2007 What would be the most handy way to reset? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 4, 2007 Share Posted December 4, 2007 Either remove the battery leads for about half an hour or remove 2 fuses in the fuse box - iirc they are the 2 labelled as EFI 1 and 2 Thats normally for the TT, im not 100% sure that its the same for NA Quote Link to comment Share on other sites More sharing options...
Guest mossy86 Posted December 4, 2007 Share Posted December 4, 2007 Tried the EFI 1 took out codes still up on dash..there's no EFi2 Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 4, 2007 Share Posted December 4, 2007 Either remove the battery leads for about half an hour Are you sure that's long enough? Pulling EFI1 fuse for a few seconds will clear the ECU of stored codes and not lose all your radio stations. Then try checking the codes before even starting the car - it should be completely free of them. -Ian Quote Link to comment Share on other sites More sharing options...
Guest mossy86 Posted December 4, 2007 Share Posted December 4, 2007 Ok i disconnected the batt for few hours...tried again, now I only have code.....24 Quote Link to comment Share on other sites More sharing options...
