Coil Pack Connection Q?
DrivingTheDream
Ok I have a "misfire" problem and after changing the plugs my next step is to refurb the coil packs or change them.
I asked my Brother who had a look the other day when I done the plugs. He says is not possible to bypass the connectors and solder the wires directly on to the connecting block instead of the refurb technique of tightening the connecting pins?
Or is it just as easy and guaranteed to work to do the refurb?
Will it not cause hassle later on when changing the plugs?
Don't solder them, you won't be able to remove them if you do.
The coil pack connectors are the things that need changing on most cars as the white insulating clips have a tendancy to break after a good few years. The coil packs themselves should be fine.
The connectors are about £6 each, the coil packs something like £60 each!
£55 each and darryls right its usualy the connecters themselves at fault not the packs as i discovered;)
I broke all my connectors and I had to fit 12 small female spade connectors to fit onto the pins on the coil packs. you can easily but carefully tighten these spade connectors if ever needed.
Just be sure to wire them up correctly for positive and negative otherwise your spark will be very very weak to the point where it will struggle to ignite anything at all.
Yeah thats what I'm thinking, When you say connector-Are you referrring to the full black plastic part or just the white middle piece?
Also how safe/unsafe is it to use without the connectors on and wires just secured in place? I want to take it round the block to see if theres any difference.
Connector is the black plastic part and the white middle insert to, all one piece.
I wouldn't do it personally, we change LOADS of these connectors here, nearly always the missfire is caused by this. But we are getting more and more with coil pack problems as well, thats why I've recently started keeping these in stock as well.
Ta
Ta
got mine from paul^^ top guy, great price, received next day, missfire cured!:D
